i recently added the Kostal Solar integration and now receive a lot of data, which are quite useful, eg, Energy consumption of current month, current power consumption,…
Now i thought i could use one of them for my energy calculation but i keep receiving the notification that there are no statistic values available:
So i changed the code accordingly, but still no appearance. Also a already checked the page you recommended. Ist the path /config/customize.yaml correct for the customize-file?
Ist there any way i can check why it’s not working/showing up?
So after i added some sensors from my Kostal-Integration, two of them actually showed up in the dropdown, which made me quite happy. Even though knowing that “total consumption from grid” is not the correct parameter, i picked it for testing. Now it seems to work. HA then appearantly created an own sensor (the last one on the very bottom):
So progress yes, perfect no. How can i alter the sources for “Energy” once i set them up initially?! (see next post as i can only add one embedde picture)
there seems to be no “Edit”-button or else. As “Energy” is also not an integration or add-on (correct me if I’m wrong), i don’t know how to change the parameters.
Go back to the Configuration / Dashboards / Energy settings page and you will see a pencil icon and a garbage bin next to each sensor you have added. Pencil = edit, garbage = delete.
Found it! in my GUI it’s three little dots which are barely clickable but seems to be a resolution issue, shame on me. Thanks for that. What i discovered is that if a activate sensors from my Kostal-Integration get available in the dropdown:
but the “custom made” ones are not availble. So i assume i configured the file not correct or sth. I tried it by costumzie a sensor so it will be the same setup as one of the generic ones which are available:
generic one (available in dropdown):
state_class: total_increasing
unit_of_measurement: kWh
device_class: energy
friendly_name: scb Home Consumption from Grid Total
customized one (not available in dropdown):
sensor.scb_home_consumption_from_grid_month:
friendly_name: scb Home Consumption from Grid Month
# last_reset: '1970-01-01T00:00:00+00:00'
So two possible issues to be assumed:
The customized sensor cannot be accessed/detected
The Energy-Dashboard accepts only “total-total” values as my customized is “per month”.
Yes, i reloaded the whole HA application and as the generic sensors keep appearing in the dropdown the issue only affects customized sensors. Nevertheless maybe it’s even correct to have “total consumption” over “consumption of current month” and HA itself then limits the period of observation by day, month, etc., might that be right?
Because i now chose the total amounts of each and it seems to work (correct me if I’m wrong):
But still bothers me that i cannot use customized sensors as they should be set up the very same and i could image that this problem will affect me someday again
