I am trying to create a sensor that display quotes randomly using template sensor. This is what I did…
sensors:
random_motivational_quotes:
friendly_name: 'Random Motivational Quotes'
value_template: >-
"Quote 1",
"Quote 2",
"Quote 3"
] | random }}
Unfortunately, my HA will not load each time I put up this sensor.
I am wondering why?
keithh666
(Keith Hull)
February 9, 2018, 12:20pm
2
It works for me on Win 10 HA 62.0 (direct install) except that it changes every few milisecs when displayed in a group.
Edit: Changed it to use a time function to change quotes a bit more slowly…
sensors:
value_template: >-
{% set time_now = states('sensor.time').replace(':', '.')|float %}
{% if time_now < 7 %}
"Quote 1",
"Quote 2",
"Quote 3"
] | random }}
{% elif time_now < 13 %}
"Quote 4",
"Quote 5",
"Quote 6"
] | random }}
{% elif time_now < 15 %}
"Quote 7",
"Quote 8",
"Quote 9"
] | random }}
{% elif time_now < 18 %}
"Quote 10",
"Quote 11",
"Quote 12"
] | random }}
{% else %}
"Quote 13",
"Quote 14",
"Quote 15"
] | random }}
{% endif %}
thanks. i modified your sample a little bit to this…
sensors:
value_template: >-
{% set quotes = [
"Quote 1",
"Quote 2",
"Quote 3"
{% if time_now < 1 %}
{{quotes|random}}
{% elif time_now < 2 %}
{{quotes|random}}
{% elif time_now < 3 %}
{{quotes|random}}
{% elif time_now < 4 %}
{{quotes|random}}
{% elif time_now < 5 %}
{{quotes|random}}
{% elif time_now < 6 %}
{{quotes|random}}
{% elif time_now < 7 %}
{{quotes|random}}
{% elif time_now < 8 %}
{{quotes|random}}
{% elif time_now < 9 %}
{{quotes|random}}
{% elif time_now < 10 %}
{{quotes|random}}
{% elif time_now < 11 %}
{{quotes|random}}
{% elif time_now < 12 %}
{{quotes|random}}
{{quotes|random}}
{% elif time_now < 14 %}
{{quotes|random}}
{{quotes|random}}
{% elif time_now < 16 %}
{{quotes|random}}
{% elif time_now < 17 %}
{{quotes|random}}
{{quotes|random}}
{% elif time_now < 19 %}
{{quotes|random}}
{% elif time_now < 20 %}
{{quotes|random}}
{% elif time_now < 21 %}
{{quotes|random}}
{% elif time_now < 22 %}
{{quotes|random}}
{% elif time_now < 23 %}
{{quotes|random}}
{% elif time_now < 24 %}
{{quotes|random}}
{% endif %}
it loads fine now. but the sensor value keep changing every 1 minute. How to make it 1 hour?
RobDYI
February 9, 2018, 3:52pm
4
I think you can set the update of template sensor to match a state change of entity_id: in the configuration. If you make a hour time sensor that shows the hour of the day, then i think you can use
sensors:
entity_id: sensor.hour_of_the_day
value_template: >-
"Quote 1",
"Quote 2",
"Quote 3"
] | random }}
