How to create virtual power and energy meters for your smart devices
If you can see the state of a device from Home Assistant, in most cases you can create a virtual energy sensor for it.
In this example, I will create a template power meter sensor and use it with a Home Assistant integration called Riemann sum integral to create an energy sensor for a ceiling fan, so it can be tracked in the energy dashboard.
Electrical power is measured in units of power called Watts. It shows how much power a device is using at an instant. (Power or Watts is Joules of energy over time but let’s keep things simple.) Energy is how much power is used over a time and it is measured as W/time and commonly used as kWh (kilo Watts per hour). Energy is always calculated by power over a certain time, that’s why an integral operation is required for the measured time. In reality even AC voltage is calculated over time using integration with proper meters. (RMS Voltage)
My fan entity fan.livingroom_ceiling_fan has 6 speed settings (16%, 33%, 50%, 66%, 83% and 100%) and an on/off state. It also has a reverse/forward direction setting but since the difference in power consumption was so small I decided to disregard it and instead calculated an average consumption over time including over both directions. I used a real power meter to measure its consumption and here is a list showing its average consumption.
fan off = 0 W
fan speed at 16% = 5.94 W
fan speed at 33% = 7.98 W
fan speed at 50% = 12.99 W
fan speed at 66% = 17.93 W
fan speed at 83% = 23.07 W
fan speed at 100% = 37.14 W
To do this correctly we have to add a small amount of fluctuation to our virtual power meter, just like how a real one works. In average this will not have any affect on our data. If we won’t do this, integration will not work because for the sake of efficiency, Home Assistant does not create periodic data points if the value has not changed. Since integration works over time, it will not be able to integrate over a time where no data points are present. So we will add a small random fluctuation to our template power sensor from a range of -0.05 W to 0.05 W.
The template {{ (range(-5, 5)|random/100)|round(2) }} will give us this fluctuation and we will add this to our power value.
Also we want our virtual power meter to make a measurement every 2 seconds, so we need fluctuating data points every 2 seconds. To do this we will use a Trigger-based Template sensor.
Here is how I made mine:
template:
  - trigger:
      - platform: time_pattern
        seconds: '/2'
      - name: Template PM Living Room Fan Power
        icon: 'mdi:flash'
        device_class: power
        unit_of_measurement: "W"
        state_class: measurement
        state: >
          {%- if is_state("fan.livingroom_ceiling_fan", "on") -%}
            {%- if is_state_attr("fan.livingroom_ceiling_fan",'percentage', 16) -%}{%- set pwr = 5.94 -%}
            {%- elif is_state_attr("fan.livingroom_ceiling_fan",'percentage', 33) -%}{%- set pwr = 7.98 -%}
            {%- elif is_state_attr("fan.livingroom_ceiling_fan",'percentage', 50) -%}{%- set pwr = 12.99 -%}
            {%- elif is_state_attr("fan.livingroom_ceiling_fan",'percentage', 66) -%}{%- set pwr = 17.93 -%}
            {%- elif is_state_attr("fan.livingroom_ceiling_fan",'percentage', 83) -%}{%- set pwr = 23.0 -%}
            {%- elif is_state_attr("fan.livingroom_ceiling_fan",'percentage', 100) -%}{%- set pwr = 37.14 -%}
            {%- endif -%}
            {{ (pwr + range(-5, 5) | random/100)|round(2) }}
          {%- else -%}
            0.00
          {%- endif %}
Now we can use this power sensor data to create our energy meter:
  - platform: integration
    source: sensor.template_pm_living_room_fan_power
    name: "Template PM Living Room Fan Integral"
    unique_id: template_pm_living_room_fan_integral
    round: 0
It is important to include round: 0 because it will give us an energy reading resolution of 1W/h and that will create more than enough data points. If we don’t include it, there will be too many data points since the default rounding is 3. You should also be able to do this integration using the GUI with helpers as well.
Below is how to create the same energy sensor from the helper GUI if you don’t want to create it using YAML.
Add integral helper, enter input sensor, give it a name, set precision to 0, keep prefix at none and leave time unit in hours. That’s it!
Wait a couple of hours for the energy sensor to become available in the energy dashboard.
Now you can create energy sensors for all your smart devices.
I would also like to mention a bit about how electrical consumption works because even though this virtual power meter sensor approach is great for so many devices, it will not work properly on some devices, such as TVs or amplifiers which have an unpredictable range of consumption depending on volume or image.
Additionally, you might also think that this approach should work perfectly with simple devices such as heaters which are nothing more than a resistor. However the reality is that the resistance of the heating element changes with temperature which will cause the drawn current to change which will result in change in utilized power. The same also applies to electronics as well, as their efficiency changes with temperature.
On top of all this, your mains voltage will fluctuate over time as well. Here is how my 3 phase mains voltage looks over 24 hours. As you can see there is a fluctuation of about 10Volts in 24 hours in my case. However in a 24 hour average it is always very close to 230V.
Everything that has an effect on calculated power interacts with one another so power usage of even a simplest device is thus never very stable. Considering this, always use devices’ power consumption averaged over some time for this virtual power and energy meter method.
I would really appreciate it if you would share your experience and configuration if you decide to use this method.
Good luck.
Have you seen GitHub - bramstroker/homeassistant-powercalc: Custom component to calculate estimated power consumption of lights and other appliances ?
Seems interesting.
However I can not see the point though. Whenever possible, I prefer using already available Home Assistant resources and framework and create a configuration of my own than installing a component and depending on configuring it.
I know a couple of people who have tried this on Home Assistant before and failed without realizing that their problem was due to the integrator having an undocumented problem with periodic data points not being present due to using static non-changing power values.
That is the only trick to it and I have presented a simple method to avoid that. Other than that it is a straight forward template sensor configuration.
I find configuring your own template sensor to be a lot more versatile than depending on a custom component. However, I think a custom component might be interesting for someone who can not write a couple lines of jinja template and a couple lines of yaml to create a simple template sensor configuration. Yet the powercalc component is using yaml configuration too so I don’t know. :slight_smile:
Here is an image showing two power meters. The one on the left is from a real power meter I made with PZEM004T and the one on the right is from the method explained above.
Hi Tonguç, I tried to use your solution in a more simpler way, but is doesn’t work in anyway.
Example code for a fridge:
  - trigger:
        minutes: '/5'
      - name: Standby consumption fridge (average)
        unique_id: "standby_cons_fridge"
        icon: mdi:transmission-tower
        unit_of_measurement: W
        device_class: power
        state: <
          {{ (25.00 + range(-5, 5) | random/100)|round(2) }}
Also tried that with bigger random values like
      {{ (25.00 + range(-2, 2)) |round(2) }}
… but unfortunately there’s no data recorded. Configuration check says everything is fine.
Do you or anyone else have an idea what I’m doing wrong?
With that logic you need to write your own Home Assistant like server, because u cant trust to someone else solution…
your example has a little typo. in state you need “greater than”
    state: >
i came around this post and tried your example because it fits my needs.
Now it is working for me.
PowerCalc is now part of HA proper. PowerCalc seems to come up more now.
Should PowerCalc be used instead of “Integration - Riemann sum integral”?
I have some devices that are covered by two power/energy monitors, is there an easy way to subtract the device specific monitor energy/power from the multiple outlet energy/power. The Emporia system monitors at the breaker level. Shelly and Kasa 115 device monitor at the socket/switch
It’s different matters.
PowerCalc is for when you don’t have power or energy meters. It then work on estimates. It’s virtual.
The Riemann integration is to take power to energy from an actual power meter.
actually, Powercalc does all of the above…
you can create virtual mappings, but also have it use power sensors. make it group all if you entities, or parts of them, you name it.
You can have it do all the work for you, and even automate the creation of utility meter entities etc etc.
not sure why you mean here, unless it’s a typo… Powercalc is custom, and Not part of core HA.
Probably best too, because its development is even more active and faster than HA :wink:
If you go to the HA integration page and search for PowerCal it shows up. You don’t’ have to pull it from HACS or grab it off github. I figured that meant HA development saw it as a primary component. So maybe saying it’s part of HA isn’t proper language, but for me if it’s included off the main integration link, that seems like the stamp of approval.
Not sure there, I suppose it means you have it installed and it is available in your system
Check the integrations on the Home Assistant website itself, it won’t show up there
Sure, it provides that functionality too, but in my view it’s unnecessary if you can use built-in solutions.
I get that you’re referring to this:
Energy from real power sensor
Use this when you have an existing power sensor in your installation, which you want to create energy sensor (and optionally utility meters) for. This also makes it possible to add the power sensor to a powercalc group.
Energy sensors and utility meters
When setting up power sensors using the above methods Powercalc can automatically create an energy sensor (kWh) and optionally utility meters (sensors which cycle each hour, week, month). The can be toggled in the GUI or use the YAML options create_energy_sensor and create_utility_meters globally or per sensor.
Form the docs, the original intent is quite clear (which is why I made my earlier but more brief statement):
PowerCalc is a custom component for Home Assistant to estimate the power consumption (as virtual meters) of lights, fans, smart speakers and other devices, which don’t have a built-in power meter.
These extras are nice, but asking (as @bkprath did) whether it should be used is another matter. It’s not like it’s a one to one replacement.
My point was to say these are different things.
My answer to that is still no: There’s no mandate.
You should check Integrations - Home Assistant for official integrations. No need to guess.
Yeah, I just check on a second house I have set up where I haven’t started doing any energy monitoring and it is not is available from the main integration page.
Hi Planzo,
Sorry for the late reply.
I hope you fixed your problem by now.
However, I want to point out a couple of things.
First, your template sensor is not depending on any state change. Which means the consumption will be same per day or month. You can simply just do that.
Second, fridge consumption is more complex than light or fan. It depends on how many things you put inside and how many times you open it and the ambient temperature of your house etc. So I would recommend on using a real meter on a frigde. Here is some data from how a real fridge power reading looks like. First one is from Feb, next image is yesterday.
I hope this helps.
I don’t know if you’re trolling but you’re mistaken. Nobody is suggesting someone to write a server. I’m not really sure how you came to that conclusion. If you think writing a couple of lines of very simple code is similar to writing a server, you need to check you logic again.
The idea is that Home Assistant already provided enough tools to do many things without depending on 3rd party software. Similar to how you write your automations or scripts in Home Assistant, to can write simple templates. You don’t have to. The idea is about developing your skills for using the available tools which are essential in Home Assistant. You CAN depend on other peoples solutions. There’s no shame in that. You can even depend on other peoples servers and not even use Home Assistant. You’re free to do what you want man. You don’t have to feel threatened. Definitely not by the templates :slight_smile:
The subject and example is about the idea, not about writing code. Code writing is already expected in the Home Assitant community but is not necessary.
Yes, I’m actually doing this as well.
In my setup, I have a power reading from the main electrical meter. It is a small device I made using a 1$ LDR module connected to an ESP8266 running ESP Home. I also have many individual real power monitors throughout the house as well as template virtual power sensors as described above. I made a template sensor that adds all of the individual meters. I also have another template sensor that takes the difference between the service meter and the sum of individual meters. In my case, I’m using that to track down significant unaccounted consumption in the house. However the implementation is the same as what you want.
Here is the code:
  - sensor:
      - name: "Total Individual Power"
        unique_id: pm_total_individual_power
        device_class: power
        state: >
          {% set power_list = [ states('sensor.pm_fridge_power'),
                                states('sensor.pm_dishwasher_power'),
                                states('sensor.pm_washing_machine_power'),
                                states('sensor.pm_dryer_power'),
                                states('sensor.pm_studio_power'),
                                states('sensor.pm_aquarium_power'),
                                states('sensor.pm_efe_s_room_power'),
                                states('sensor.pm_bedroom_power'),
                                states('sensor.pm_fancoil_power'),
                                states('sensor.pm_it_power'),
                                states('sensor.pm_ac_power'),
                                states('sensor.pm_kitchen_power'),
                                states('sensor.pm_home_theater_power'),
                                states('sensor.template_pm_water_heater_power'),
                                states('sensor.template_pm_living_room_fan_power'),
                                states('sensor.template_pm_living_room_fan_light_power'),
                                states('sensor.template_pm_window_light_1_power'),
                                states('sensor.template_pm_window_light_2_power'),
                                states('sensor.template_pm_studio_light_power'),
                                states('sensor.template_pm_entrance_light_power'),
                                states('sensor.template_pm_bathroom_fan_power')
          {%- set invalid_values = ['unavailable', 'unknown'] %}
          {%- set power_list_valid = power_list | reject('in', invalid_values)| map('float', default=0) | list %}
          {%- if power_list_valid %}{%- set power = power_list_valid |map('float',default=0)| sum | round(1, 'common', default=0) -%}
            {{ power }}
          {%- else -%}
            0
          {%- endif -%}
  - sensor:
      - name: "Remaining Power"
        unique_id: pm_remaining_power
        unit_of_measurement: 'W'
        device_class: power
        state: >
          {%- set remaining_power = (( states('sensor.house_power_consumption') | replace('unavailable', 0) | replace('unknown', 0)| default(0)| float | round(1)) -
            ( states('sensor.total_individual_power') | float | round(1)))| round(1) -%}
          {%- if remaining_power <= 0 -%} 0 {%- else -%} {{remaining_power}} {%- endif -%}
  - sensor:
      - name: "Remaining Power Percentage"
        unique_id: pm_remaining_power_percentage
        unit_of_measurement: '%'
        device_class: power
        state: >
          {{ (states('sensor.remaining_power')|float/states('sensor.house_power_consumption')|float*100)|round(1, 'common') }}
Thanks for the details. I’ll see if I can take advantage of your efforts.
