Hi, I currently have two automation in Apple Homekit for the househould, where lights turns off and on with “when last person leaves” & “when first person arrives” automation. I would like to tranfer this automation to my Home assistant. But I am not sure how. I currently have two users with iPhones set up as tracking devices. But I am uncertain how to configure the trigger. Any suggestions?
create a template sensor (Template - Home Assistant) which counts the device trackers at home and use it as numeric_state trigger (Automation Trigger - Home Assistant) for your automation:
template:
- sensor:
- name: persons_at_home
icon: mdi:account-supervisor-circle
state: "{{ states.device_tracker | selectattr('state', 'eq', 'home') | list | count }}"
And the automation trigger example:
- id: nobody_somebody_home
alias: nobody_somebody_home
mode: queued
- id: 'not_home'
platform: state
entity_id: sensor.persons_at_home
to: '0'
for: '00:30:00'
- id: 'home'
platform: numeric_state
above: 0
for: '00:30:00'
EDIT / UPDATE:
As of 2022.5 the way zones work have changed and many groups (though, not person groups) can now be set up in the GUI. With these changes, it is now easier to use a numeric-state trigger based on the zone.home entity.
- platform: numeric_state
entity_id: zone.home
below: 1
- service: light.turn_off
You can create a group
EDIT : @Didgeridrew you was faster than me
Yes, as long as your configuration.yaml includes the new groups.yaml. If the device trackers are already assigned to a person, you don’t need to include them in the group.
I noticed today that the automation did not trigger. I can read from the log that group family have been detected away, but the automation wont start:
This is how my group looks like; tracker device is one iPhone each.
I notice there is an error in the automation;
Group family is set as away, but no further action to my automation;
When binary goes on, at least 1 person is home. If it goes off, everybody is away.
binary_sensor:
sensors:
somebody_home:
friendly_name: Somebody home?
value_template: >
{% if (states('person.1') and states('person.2') and ...... and states('person.n')) != 'home'%}
off
{% else %}
on
{% endif %}
Thanks for reply. I tried this one. Created the sensor, but I can´t get that numeric state trigger configured. Struggeling to close the code. Could you please paste the full code in code format?
Just use a State trigger, not a Zone trigger:
- platform: state
entity_id: group.family
to: not_home
Even though it is displayed in the frontend as Home or Away, the group’s state is actually ‘home’ or ‘not_home’. It will be ‘home’ when the first person comes home/as long as 1 person is home and ‘not_home’ after the last person leaves.
EDIT / UPDATE:
As of 2022.5 the way zones work have changed and many groups (though, not person groups) can now be set up in the GUI. With these changes, it is now easier to use a numeric-state trigger based on the zone.home entity to determine whether the house is occupied or not.
below: 1
Thanks a lot, I will give this a try.
alias: Turn All Lights off When We Leave
- entity_id: group.family
platform: state
to: not_home
condition: []
data: {}
entity_id: light.alle_lys
I’m struggling with the same issue. I used a helper switch (input_boolean) instead of the device tracker because the update of the device tracker is way later then when someone arrives home, so I adjusted the code a bit to.
"{{ states.input_boolean | selectattr('state', 'eq', 'on') | list | count }}"
This works but it counts all my boolean and I want just two specific ones (input_boolean.person1 and input_boolean.person2. I tried to change the code but I cant get it to work. hope someone can help me with this.
{{ expand('input_boolean.person1', 'input_boolean.person2')
Wow you are good. it works. Wish I had a list with all possible commands and how to use it, or if you start typing is shows what it expects, a bit like you have with VBA or PowerApps.
Any way many thanks!!!
Hi! I was looking for a solution for my case and I found yours. How do you think that I can make it work your automation but only once a day? Because I want to automate the vacuum cleaner. I want to start it when everyone is out of home, but, obviously, I only want it to make it once a day.
Thanks in advance.
You can add a Template condition to throttle how often the automation fires.
triggers:
- trigger: numeric_state
below: 1
conditions:
- alias: Run only if today's date is not the same as the last date this automation ran
condition: template
value_template: |-
{{today_at().date() != (this.attributes.last_triggered | default(as_datetime(0),1)).date() }}
actions:
- actions: light.turn_off
entity_id: light.example
Wht do you think about this solution? It would be optimal if I want to trigger the automation between certain hours and once a day:
triggers:
below: 1
conditions:
condition: template
value_template: >
{% set nw = now() %}
{% set last = state_attr('automation.ventilate_game_room', 'last_triggered') %}
{{ 10 <= nw.hour < 20 and
(last is none or (nw - last).total_seconds() > 10 * 60 * 60) }}
actions:
Or maybe this one:
triggers:
below: 1
condition:
- condition: time
after: '10:00:00'
before: '20:00:00'
- "{{ state_attr(this.entity_id, 'last_triggered') < today_at('10:00') }}"
actions:
If it meets your needs, it’s fine.
The reason I used the this variable instead of the state_attr() function is habit. In the actions block, (like in conditions of an If/Then or Choose action) this.attributes.last_triggered and state_attr('automation.example', 'last_triggered') will have different values, so you have to be careful to use the right one for the circumstance… the this version is almost always the value that is actual wanted, so I use that version in the conditions block as well.
EDIT: Added explanation for use of this
This seems to be simpler if I want to add a time window, isnt’ it?
