I finally made the jump to HA and so far I love it!
Hopefully this is an easy question. I’m attaching a picture of my rudimentary dashboard. I have a heading called ‘thermostats’ and the device names reference ‘climate’ objects. (actual thermostats)
But I have a zigbee temp and humidity sensor that I’d like to display in a similar fashion. How can I ‘trick’ HA into displaying my master bedroom Temp sensor in the same format as my thermostat?
I finally got this working. So now I see an entity for a new thermostat. Now where I am confused is how do I get this virtual thermostat to use the values from my actual temp sensor?
I think if I can do that, HA should treat it like an actual thermostat and I should get the behavior I am looking for.
Just post your questions here.
We have all been in your situation and the learning curve can be pretty steep, especially if you are not using the forums here.
