How to customize DOODS to recognize numbers?
Is it possible to customize DOODS to recognize numbers in a display?
I’m planning to have a camera pointing to an old alarm display and trigger automations based on that.
Doods is probably not good fit for this but not sure
Probably take a look at ALPR in generic Image Processing integration. I test this before with license plate recognition and it worked well
I’m not sure if the use case so hard to recommend anything but there are several other integrations, like OCR, that are specific to text/number recognition and would probably perform your desired task
Thanks for the reply!
I did try ALPR, but it gives a “no license plate recognized” message.
Actually, OCR is a great idea! It was only after your message that I searched for OCR integrated into Home Assistant. I will try to implement SSOCR in my project. Thanks for the good idea.
I think it test ALPR,but maybe it was one of the Microsoft integrations, with license plate. It was test not real condition but it work when license was full frame in camera
