Sturmkater
(Sturmkater)
December 13, 2022, 2:30pm
1
I got an TS004F rotary knob to remotely control my LED light stripes. The goal is to use the ‘zigbee2mqtt/Stube MediaRemote/action’, payload ‘color_temperature_step_down’ and up to cycle throw colors.
There is a Blueprint for this knob, but just for ZHA, but I did not manage to get it running with Z2M.
There is an other one witch is a loop animation, but I did not manage to get this one working when trigered by a button instead by time.
Thanks for help:-)
123
(Taras)
December 13, 2022, 2:43pm
2
Perhaps you can use this as the basis for a solution:
Create an Input Select containing the names of the colors want:
red
blue
green
white
Then create the following automation:
alias: color changer
- platform: state
entity_id:
- sensor.sonoff_bedroomr5
to: button_3_single
condition: []
- service: light.turn_on
color_name: "{{ states('input_select.colors') }}"
brightness_pct: 100
device_id: bedroomled
- service: input_select.select_next
entity_id: inpu…
You will need to replace the example’s State Trigger with an MQTT Trigger .
Let me know if you need more help to compose the automation (or if the example doesn’t meet your requirements).
Sturmkater
(Sturmkater)
December 13, 2022, 3:22pm
3
Hey Taras, thaks. Your way worked! Nice
Now I have 10 automations regarding this remote, one for each input action. Is there a way to put all thous automations in one?
123
(Taras)
December 13, 2022, 3:25pm
4
Yes. Post three or more of the ten automations (or all ten) and I’ll show you how to consolidate them.
Sturmkater
(Sturmkater)
December 13, 2022, 4:00pm
5
sweet, thaks!
alias: MediaRemote ColorDown
description: ""
- platform: device
domain: mqtt
device_id: e5edc01b727ac1a02a8cb44a6c2c1387
type: action
subtype: color_temperature_step_down
discovery_id: 0x04cd15fffe23ecb2 action_color_temperature_step_down
condition: []
color_name: "{{ states('input_select.colors_3') }}"
brightness_pct: 100
device_id: 98d1ca44296ab7a594b73e341a276340
entity_id: input_select.colors_3
data: {}
mode: parallel
alias: MediaRemote ColorUp
description: ""
- platform: device
domain: mqtt
type: action
subtype: color_temperature_step_up
discovery_id: 0x04cd15fffe23ecb2 action_color_temperature_step_up
condition: []
brightness_pct: 100
- service: input_select.select_previous
data: {}
mode: parallel
alias: MediaRemote decrease brightness
description: MediaRemote Light
- platform: device
domain: mqtt
type: action
subtype: brightness_step_down
discovery_id: 0x04cd15fffe23ecb2 action_brightness_step_down
condition: []
- device_id: 98d1ca44296ab7a594b73e341a276340
domain: light
entity_id: light.led_stripe_stube
type: brightness_decrease
mode: parallel
alias: MediaRemote Increase Brightness
- platform: device
domain: mqtt
type: action
subtype: brightness_step_up
discovery_id: 0x04cd15fffe23ecb2 action_brightness_step_up
condition: []
domain: light
type: brightness_increase
mode: parallel
alias: MediaRemote Next
description: ""
- platform: device
domain: mqtt
type: action
subtype: double
discovery_id: 0x04cd15fffe23ecb2 action_double
condition: []
- service: media_player.media_next_track
data: {}
entity_id: media_player.hifiberry_192_168_1_21
mode: single
alias: MediaRemote PlayPause
description: ""
- platform: device
domain: mqtt
type: action
subtype: single
discovery_id: 0x04cd15fffe23ecb2 action_single
condition: []
- service: script.kodi_play_pause
data: {}
mode: single
alias: MediaRemote VolumeDown
description: ""
- platform: device
domain: mqtt
type: action
subtype: rotate_left
discovery_id: 0x04cd15fffe23ecb2 action_rotate_left
condition: []
- service: media_player.volume_down
data: {}
mode: parallel
alias: MediaRemote VolumeUP
description: ""
- platform: device
domain: mqtt
type: action
subtype: rotate_right
discovery_id: 0x04cd15fffe23ecb2 action_rotate_right
condition: []
- service: media_player.volume_up
data: {}
mode: parallel
123
(Taras)
December 13, 2022, 5:06pm
6
The examples you posted use MQTT Device Triggers. It’s simpler to consolidate automations employing MQTT Triggers.
To use an MQTT Trigger, we need to know the topic that the device publishes to and examples of the payloads that are published. I’ll take a guess that the payloads are rotate_right, rotate_left, single, double, etc but I’ll need to know the topic.
Sturmkater
(Sturmkater)
December 15, 2022, 12:31pm
7
hmm, there are several things marked as topic:
Topic: homeassistant/sensor/0x04cd15fffe23ecb2/action/config
Payload
availability:
- topic: zigbee2mqtt/bridge/state
device:
identifiers:
- zigbee2mqtt_0x04cd15fffe23ecb2
manufacturer: TuYa
model: Smart knob (ERS-10TZBVK-AA)
name: Stube MediaRemote
enabled_by_default: true
icon: mdi:gesture-double-tap
json_attributes_topic: zigbee2mqtt/Stube MediaRemote
name: Stube MediaRemote action
state_topic: zigbee2mqtt/Stube MediaRemote
unique_id: 0x04cd15fffe23ecb2_action_zigbee2mqtt
value_template: '{{ value_json.action }}'
platform: mqtt
Yes, the payloads are the one stated by you, rotate_right and so on.
123
(Taras)
December 15, 2022, 2:24pm
8
Here’s the general idea (it may require adjustments).
alias: MediaRemote Control
description: ""
mode: parallel
- platform: mqtt
condition: []
- variables:
light: light.led_stripe_stube
player: media_player.hifiberry_192_168_1_21
- choose:
- conditions: "{{ trigger.payload in ['color_temperature_step_down','color_temperature_step_up',] }}"
sequence:
brightness_pct: 100
entity_id: '{{ light }}'
- service: "input_select.select_{{ 'next' if 'down' in trigger.payload else 'previous' }}"
- conditions: "{{ trigger.payload in ['brightness_step_down','brightness_step_up',] }}"
sequence:
brightness_step_pct: "{{ -10 if 'down' in trigger.payload else 10 }}"
- conditions: "{{ trigger.payload == 'double' }}"
sequence:
entity_id: '{{ player }}'
- conditions: "{{ trigger.payload == 'single' }}"
sequence:
- service: script.turn_on
entity_id: script.kodi_play_pause
- conditions: "{{ trigger.payload in ['rotate_left','rotate_right',] }}"
sequence:
- service: "media_player.volume_{{ 'down' if 'left' in trigger.payload else 'up' }}"
default: []
Each choice in choose handles one or two of the received commands:
color up/down
brightness up/down
double click
single click
rotate left/right
