my hassio calendar does no longer show, I assume the calendar.create_event service messed something up. Is there a way to look at the calendar events database via the file viewer and manually delete the last couple of entries, so I don’t lose the others?
THanks
Data is stared under /config/.storage/local_calendar.<your_calendar_name>.ics
But be careful and make a copy of the file before you edit it.
