2024-05-07 19:11:28.587 WARNING (MainThread) [py.warnings] /usr/local/lib/python3.12/site-packages/tzlocal/unix.py:193: UserWarning: Can not find any timezone configuration, defaulting to UTC.
warnings.warn(“Can not find any timezone configuration, defaulting to UTC.”)
The operating system of your platform doesn’t have a timezone set. If you were running HAOS, this should be taken care of you – you could confirm the timezone setting by checking the Settings > System > Timezone or by ssh’ing to your HA host and running echo $TZ.
Since you’re seeing this warning, I’m presuming you are not running HAOS – I think you’ll need to share your installation method for anything more specific than that.
Explain to a 36 year career IT person what is a warning vs an error. In my past experience a warning set by a developer who took time to do so, means that something is not right and it is brought to your attention as it may get worse.
Your reply is useless.
Thanks @francisp . My TZ is set through my config yaml for years and reported correctly in the settings system general. And the Dev tools check config is all green.
I honestly really think that it is something in the integrations custom / or not since it is reported at restart and usually in between integrations load.
