I am new in the Home Assistant world, installed Home Assistant and tried to connect some devices. No problem for some supported devices, but not for my NOUS E6 Thermometer and Humidity sensor.
and I really have no idea which steps I need to take (and how)
to include, use and setup the findings as described on the git page
My feeling is that I first have to install and configure all kind of things before I can install and use the github code from the example. But perhaps / hopefully I am wrong.
Can someone give me a hand / explain what exactly to do starting from a fresh Home Assistant install !?
I just received a mail saying that In order to install the quirk manually you need to create the “quirks” sub-directory in your HomeConfig directory. Then in “quirks” dir create a file, say “nous_e6.py”, and paste the quirk. Save the file. Restart HA.
But perhaps very stupid, but I really have no idea how to dot that from the GUI.
After some help and a lot of investigation I finally have the device working. However a lot of steps where needed.
So for every body new like me, I describe the steps below.
Preparations
make sure that the computer you use does reboot after a power outage
take care in your dhcp server that home assistant gets every time the same IP-address
you should have a ssh-client installed on your (windows) computer e.g. Bitvise SSH client
After a fresh Home Assistant install take the following actions:
Advanced Configuration htt_ps://www.home-assistant.io/getting-started/configuration/
go to you personal user settings at the left botum of the screen homeassistend-ip:8123/profile
Advanced Mode => ON (required for more advanced actions like this one)
Advice: make sure that the user has only access from the local network !!
install the ^file editor^ and the ^terminal / SSH^ app
settings
add-ons
add File editor and set it to be added to the sidebar (auto update and boot on probably), start it
add Terminal & SSH (DO NOT USE SSH & WEB-terminal, it did not work!)
click on the Terminal & SSH add-on and configure the SSH-server (configuration)
Go to the page where the code / info is related to the ^not yet supported device"
Make the “quirks” directory kown to the main configfile
Add guide for adding a custom quirk to ZHA #23884 htt_ps://github.com/home-assistant/home-assistant.io/pull/23884/files#diff-f6bd4d42fd2565238968333a466474a25384fb4eecddc0235902e5ff5e798c8dR422-R435
there is an error tn that webpage. The configfile is NOT “config.yaml” BUT “configuration.yaml”
start the file editor and open via the folder symbol on top “/config/configuration.yaml”
add at the botum
zha:
custom_quirks_path: /config/zha_quirks/
safe
Goto Developerstotools (sidebar)
check configuration
if ok “restart”
The device should be recognised now
and can be edited
and placed on your dashboard
however … I had to remove and place the battery of the device … before it “worked”
Some further parameter tuning is needed but at this moment I do not yet know how
has to do with options related to “Manage Zigbee Device and cluster settings” Really no idea yet
