How to delete a ghost device?
Specifically, I removed an old Sonos Connect from my audio system. The Sonos integration still shows the old Connect as a device and I see no way to delete it. However, it does not show as an entity, which is correct, but still shows as a device.
Cog icon at the top right of the device’s page.
I tried that. It just brings up a window to change the name and the area. Nothing about deleting.
I already had that. Mostly from deconz.
just restart home assistant a few times. That’s how I got rid of it.
Thanks for the reply, but that hasn’t worked, at least not yet. I’ve restarted HA at least a dozen times over the last several days and it’s still there.
Did you find a solution for this problem? I have the exact same problem.
It’s been too long to remember specifically what happened, but I’m pretty sure it just disappeared eventually on it’s own.
I had the same problem with a Sonos speaker. Finally I solved it by “disabling” it instead of deleting it (top right corner > Pencil > Disable Device).
