How to delete double devices in integartion?
I do have double devices added at integration (Hp printer and iPad) I don’t know how i created them double, but also don’t know how to get rid of them.
My Logfile is giving an error that there are double devices with the same name (thats correct).
I did look at entity section, but also not possible to delete them there also.
Because I can not find them as entity?
At the section “Apparaten” (devices) they are there but can not delete them over there
The iPad does have entities but I can not delete them at entity because the delete button is grayed out
As far as I know, the only way to delete them is manually deleting them from your .storage file.
NOTE: make a backup of the file before you even attempt to edit/delete a character in that file.
What I did was rename the entities through the UI by adding “_old” to the end to make it easier to find in the file. The file can only be edited while HA is shutdown. You mileage may vary, but if a mistake is made you will have the backup of the file to try again.
pfoe exciting. I will try in the future.
HA is at the moment running smooth, so I’m afraid to kill items
Found it.
It’s imbelievable simpel.
If you select an integration at the integration page. You can delete that Integration with the bin in top right corner.
Never saw that bin :thinking:
