How to delete input_select helper - SOLVED
I created wrongly an input select helper from the UI and now i cannot delete it…
Is there a way to do this?
In the Helpers menu find your entity, click its three-dot expansion menu in the right-most column, select "Show Settings’. In the Settings pop-up that appears, scroll to the bottom and click “Delete” on the bottom left.
Sorry but there is no entry when i go to “show settings”
Have you tried restarting HA to flush the config?
Where are you seeing the entity?
Have you removed the entity’s ID from all automations, scripts, sensors, etc?
I just created the helper without putting it inside scripts or automations… about the select helpers i see there are no actions choosable, only name, ID and type…
I cannot see the helper inside entities…
EDIT: i see the helper between the entities, but also from there no chance to delete it…
EDIT2: I restarted HA, cleared cache of the browser and now i can see the ‘DELETE’ option…
