Unlike other integrations, the ESPHome integration does not appear to provide a means to delete or remove the integration? Just wondering…
Integrations show up in two different ways - for example Tuya shows like it is one integration with many devices, whereas Local Tuya shows like it is one integration per device - each device is under a sub-menu. For the former, clicking on the 3-dots and “delete” will remove the integration and all devices. For the latter, you go into each device and then click the 3-dots and “delete” - and I assume once you remove the last device, the integration is “gone”. I’ve never checked with either method if the code is actually removed. The ESPHome integration is like this, and I suspect it’s the more “modern” way to set up integrations because newer ones seem to be that way.
I was searching for this, but what I really wanted to do was to delete and reinstall the ESPHome Addon.
esphome add-on is separate from esphome integration
