This is the log when the device is OFF and I press the ON button:
Subscribed to Z-Wave JS Log Messages…
Log Level changed to: Silly
2022-06-14T23:09:40.518Z SERIAL « 0x010a00040010028201cf00af (12 bytes)
2022-06-14T23:09:40.532Z SERIAL » [ACK] (0x06)
2022-06-14T23:09:40.539Z DRIVER « [Node 016] [REQ] [ApplicationCommand]
└─[HailCC]
2022-06-14T23:09:40.547Z CNTRLR [Node 016] Hail received from node, refreshing actuator and sensor values…
2022-06-14T23:09:40.554Z CNTRLR » [Node 016] querying Binary Switch state…
2022-06-14T23:09:40.605Z SERIAL » 0x0109001310022502250ffa (11 bytes)
2022-06-14T23:09:40.609Z DRIVER » [Node 016] [REQ] [SendData]
│ transmit options: 0x25
│ callback id: 15
└─[BinarySwitchCCGet]
2022-06-14T23:09:40.615Z SERIAL « [ACK] (0x06)
2022-06-14T23:09:40.619Z SERIAL « 0x0104011301e8 (6 bytes)
2022-06-14T23:09:40.622Z SERIAL » [ACK] (0x06)
2022-06-14T23:09:40.625Z DRIVER « [RES] [SendData]
was sent: true
2022-06-14T23:09:40.948Z SERIAL « 0x011800130f00002103cfcab0b97f01010306080b0001010000ac (26 bytes)
2022-06-14T23:09:40.952Z SERIAL » [ACK] (0x06)
2022-06-14T23:09:40.958Z DRIVER « [REQ] [SendData]
callback id: 15
transmit status: OK, took 330 ms
repeater node IDs: 6, 8, 11
routing attempts: 1
protocol & route speed: Z-Wave, 9.6 kbit/s
ACK RSSI: -49 dBm
ACK RSSI on repeaters: -54 dBm, -80 dBm, -71 dBm
ACK channel no.: 1
TX channel no.: 1
2022-06-14T23:09:41.131Z SERIAL « 0x010b00040010032503ffcf00f5 (13 bytes)
2022-06-14T23:09:41.142Z CNTRLR [Node 016] [~] [Binary Switch] currentValue: false => true [Endpoint 0]
2022-06-14T23:09:41.148Z SERIAL » [ACK] (0x06)
2022-06-14T23:09:41.155Z DRIVER « [Node 016] [REQ] [ApplicationCommand]
└─[BinarySwitchCCReport]
current value: true
2022-06-14T23:09:41.164Z CNTRLR « [Node 016] received Binary Switch state:
current value: true
This is the log when the device is already ON and I press the ON button again:
2022-06-14T23:10:33.595Z SERIAL « 0x010a00040010028201cf00af (12 bytes)
2022-06-14T23:10:33.602Z SERIAL » [ACK] (0x06)
2022-06-14T23:10:33.607Z DRIVER « [Node 016] [REQ] [ApplicationCommand]
└─[HailCC]
2022-06-14T23:10:33.613Z CNTRLR [Node 016] Hail received from node, refreshing actuator and sensor values…
2022-06-14T23:10:33.618Z CNTRLR » [Node 016] querying Binary Switch state…
2022-06-14T23:10:33.633Z SERIAL » 0x01090013100225022510e5 (11 bytes)
2022-06-14T23:10:33.635Z DRIVER » [Node 016] [REQ] [SendData]
│ callback id: 16
2022-06-14T23:10:33.643Z SERIAL « [ACK] (0x06)
2022-06-14T23:10:33.647Z SERIAL « 0x0104011301e8 (6 bytes)
2022-06-14T23:10:33.649Z SERIAL » [ACK] (0x06)
2022-06-14T23:10:33.651Z DRIVER « [RES] [SendData]
was sent: true
2022-06-14T23:10:34.311Z SERIAL « 0x011800131000004303cfcaaeb97f01010306080b0001010000cf (26 bytes)
2022-06-14T23:10:34.316Z SERIAL » [ACK] (0x06)
2022-06-14T23:10:34.321Z DRIVER « [REQ] [SendData]
callback id: 16
transmit status: OK, took 670 ms
routing attempts: 1
ACK RSSI: -49 dBm
ACK RSSI on repeaters: -54 dBm, -82 dBm, -71 dBm
ACK channel no.: 1
TX channel no.: 1
2022-06-14T23:10:34.733Z SERIAL « 0x010b00040010032503ffcf00f5 (13 bytes)
2022-06-14T23:10:34.739Z CNTRLR [Node 016] [~] [Binary Switch] currentValue: true => true [Endpoint 0]
2022-06-14T23:10:34.745Z SERIAL » [ACK] (0x06)
2022-06-14T23:10:34.748Z DRIVER « [Node 016] [REQ] [ApplicationCommand]
current value: true
2022-06-14T23:10:34.756Z CNTRLR « [Node 016] received Binary Switch state:
current value: true
This is the Listen to Events tool when I subscribe to “*”:
Event 0 fired 5:11 PM:
“event_type”: “state_changed”,
“data”: {
“entity_id”: “switch.scene_capable_switch_on_off_4”,
“old_state”: {
“state”: “off”,
“attributes”: {
“friendly_name”: “PowderRoomFan”
“last_changed”: “2022-06-14T23:11:27.846853+00:00”,
“last_updated”: “2022-06-14T23:11:27.846853+00:00”,
“context”: {
“id”: “01G5J7RY36AN4ZHE8DXD6RRXXV”,
“parent_id”: null,
“user_id”: null
“new_state”: {
“state”: “on”,
“attributes”: {
“last_changed”: “2022-06-14T23:11:39.551190+00:00”,
“last_updated”: “2022-06-14T23:11:39.551190+00:00”,
“context”: {
“id”: “01G5J7S9GZGEHCZ8MN9G26H2X8”,
“parent_id”: null,
“user_id”: null
“origin”: “LOCAL”,
“time_fired”: “2022-06-14T23:11:39.551190+00:00”,
“context”: {
“parent_id”: null,
“user_id”: null
