I’ve a Zigbee network that is, in the main, quite reliable, but every once in a while one of the Xiaomi Aqara temperature sensors stops sending temperature updates. This causes problems as it means a heater I have also under control is left on, when it should be turned off when the target temperature is hit.
The solution is usually to re-pair that temp sensor so it comes back to life.
The challenge I have is how can I detect that the sensor has stopped sending temperature updates?
For example, it stopped working this morning, and last sent an update at 04:54. It didn’t send any further updates until I re-paired it at 10:46. What I’d like to do is to trigger an alarm if it doesn’t send an update for about an hour.
I’m guessing what is required is some kind of template trigger based on the last seen attribute. Anyone got any examples? (Not using Node Red please).
In case it’s relevant, the config of the temp sensor from develop tools looks like:
battery: 62
humidity: 38.98
last_seen: '2021-04-14T15:14:39+01:00'
linkquality: 42
pressure: 1027.2
temperature: 23.17
voltage: 2935
unit_of_measurement: °C
friendly_name: Cabin Temp Sensor
device_class: temperature
hide_attributes:
- templates
- icon_color
Any suggestions?
