I’m following the instructions for developing my own addon, which I want to test and run on Home Assistant Green.
I copied my addon files to the device in /addons as instructed. (presumably bare addon folders go there, not the repo folder with the addon in it)
However, I can’t seem to get past this step:
➜ ~ cd /addons
➜ /addons docker run \
--rm \
-it \
--name builder \
--privileged \
-v ./pandora:/data \
-v /var/run/docker.sock:/var/run/docker.sock:ro \
homeassistant/aarch64-builder \
-t /data \
--all \
--test \
-i my-test-addon-{arch} \
-d local
docker: Error response from daemon: error while creating mount source path '/addons/pandora': mkdir /addons: read-only file system.
The docs don’t say much about that command or how to customize it.
Looks like there’s a read-only filesystem at play somewhere… but I know it’s not /addons
because I can create files there.
So for a different approach I tried installing my starter repo as an addon repository on my device. That worked! But when I try to install the addon, I get a timeout error.
2024-02-23 23:49:27.910 ERROR (MainThread) [homeassistant.components.hassio] Failed to to call /addons/local_pandora/install - Head "https://ghcr.io/v2/home-assistant/aarch64-base/manifests/3.15": Get "https://ghcr.io/token?scope=repository%3Ahome-assistant%2Faarch64-base%3Apull&service=ghcr.io": dial tcp 140.82.112.34:443: i/o timeout
My local computer is amd64 and not Arm so I want to develop for the Green specifically, making use of the audio
system.
Thanks in advance for any pointers!
