I have just started using Home Assistant last week. It is an amazing platform. I have a question about scenes imported from ISY994. As per documentation:
All Insteon scenes configured in the ISY994 will show up as a switch in Home Assistant, as they do not support dimming or setting specific brightness settings as Home Assisstant’s light component.
My question is: I have a 3-way circuit for a chandelier. I want to turn the chandelier on/off and dim it. In ISY994 I created a scene which can easily do this. But, when the scene is imported into Home Assistant, it shows as a switch. Is there a clever way in Home Assistant to achieve a light like functionality, so the switches turn on/off and dim together?
So - I had the same question - and the short answer is, as per my understanding, this isnt possible right now. ISY doesnt provide enough information for HASS to know if a scene is dimmable or not, they are created as switches. My workaround is to have an automation set publishes and sets the correct brightness to the switch I want to have the same brightness. Its not ideal, but works well
