I don’t know when it started but for a while I’ve add this error in the logs when Home Assistant loads:
[homeassistant.setup] Setting up camera
[homeassistant.loader] Loaded ffmpeg from homeassistant.components.ffmpeg
[homeassistant.setup] Setting up ffmpeg
[homeassistant.setup] Setup of domain camera took 1.0 seconds
[haffmpeg.core] FFmpeg fails [Errno 2] No such file or directory: 'ffmpeg'
File "/srv/homeassistant/lib/python3.8/site-packages/haffmpeg/core.py", line 136, in open
self._proc = await self._loop.run_in_executor(None, proc_func)
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
File "/usr/local/lib/python3.8/subprocess.py", line 854, in __init__
self._execute_child(args, executable, preexec_fn, close_fds,
File "/usr/local/lib/python3.8/subprocess.py", line 1702, in _execute_child
raise child_exception_type(errno_num, err_msg, err_filename)
FileNotFoundError: [Errno 2] No such file or directory: 'ffmpeg'
[haffmpeg.tools] Error starting FFmpeg.
[homeassistant.setup] Setup of domain ffmpeg took 0.3 seconds
I haven’t given it that much thought since I’m not using or have installed anything that should need FFmpeg. But today when I tried to silence this error I realized that I appear to have a Camera integration installed by default that from the looks of the error above requires FFmpeg.
I don’t need any Camera integration, and I don’t need or want to install FFmpeg. How can I disable this integration or at least silence this error warning since it’s not applicable for my setup?
Here’s a (closed) related ticket for it:
