I have two switches in my esphome device and I would like to disable logging for just one of the switches. Can I do this? The reason is that one of them is included in a little loop to flash an LED and this constant turning on and off spams the logs:
[11:38:26][D][switch:013]: 'esphome_windowsensor1_whiteled' Turning ON.
[11:38:26][D][switch:013]: 'led_pin' Turning ON.
[11:38:26][D][switch:037]: 'led_pin': Sending state ON
[11:38:26][D][switch:037]: 'esphome_windowsensor1_whiteled': Sending state ON
[11:38:26][D][switch:017]: 'led_pin' Turning OFF.
[11:38:26][D][switch:037]: 'led_pin': Sending state OFF
[11:38:27][D][switch:013]: 'led_pin' Turning ON.
[11:38:27][D][switch:037]: 'led_pin': Sending state ON
[11:38:27][D][switch:017]: 'led_pin' Turning OFF.
[11:38:27][D][switch:037]: 'led_pin': Sending state OFF
[11:38:28][D][switch:013]: 'led_pin' Turning ON.
[11:38:28][D][switch:037]: 'led_pin': Sending state ON
[11:38:28][D][switch:017]: 'led_pin' Turning OFF.
[11:38:28][D][switch:037]: 'led_pin': Sending state OFF
[11:38:29][D][switch:013]: 'led_pin' Turning ON.
[11:38:29][D][switch:037]: 'led_pin': Sending state ON
[11:38:29][D][switch:017]: 'led_pin' Turning OFF.
[11:38:29][D][switch:037]: 'led_pin': Sending state OFF
[11:38:30][D][switch:037]: 'led_pin': Sending state OFF
[11:38:30][D][switch:013]: 'led_pin' Turning ON.
[11:38:30][D][switch:037]: 'led_pin': Sending state ON
[11:38:30][D][switch:017]: 'esphome_windowsensor1_whiteled' Turning OFF.
[11:38:30][D][switch:017]: 'led_pin' Turning OFF.
[11:38:30][D][switch:037]: 'esphome_windowsensor1_whiteled': Sending state OFF
So in this example, I’d like the “led_pin” turning on and off to be removed from the log output, but keep the “esphome_windowsensor1_whiteled” ones.
