How do we disable this feature that was recently added:
This makes light icon colors try to match the color temperature. Having this feature added really throws off the look of my lovelace. Now I have light icons that turn to white and disappear on my white card background. And I’ve lost uniformity with lights that aren’t color temp tunable.
I do not see that mentioned in the Release Notes. If it is in a released version it should have been documented/ The Issue you pointed to said it was merged into dev or beta… That code is not usually used in production and any issues reported on GitHub or Discord.
I want the light icon color to be the same regardless of the brightness, color temperature or RGB color. If a light is turned on I want it to be yellow, if it’s turned off grey anything else or in-between.
I also give up. My Nanoleaf Icon is somehow based on brightness. Tried everything (card-mod, themes, …) to get the state icon just yellow, if my Nanoleaf is on. Im lost now and any advice is pretty much appreciated.
