How to disable the Captive Portal pop-up window while retaining WiFi endpoint configuration?
Hello everyone,
I’m developing a smart speaker project using ESP32-S3 running ESP-IDF on ESPHome 2026.1.3.
Current configuration: I’ve enabled captive_portal: to use the /wifisave path. My app will send POST commands here to set up WiFi for the device.
Problem: Every time the phone connects to the ESP32’s WiFi AP, the operating system (iOS) automatically pops up a WiFi login request window (page 192.168.4.1). Although the setup eventually succeeds after about 20 seconds, the user is forced to remain in the operating system’s popup window. API calls from my app seem to only pass after this delay. I want to completely eliminate this annoyance by preventing the popup window from appearing in the first place, while still being able to access the /wifisave endpoint.
Desire:
Completely disable this automatic popup window when connecting to the AP.
Thank you!
api:
  reboot_timeout: 0s
  on_client_connected:
    - media_player.volume_set:
        volume: 0.3
    - if:
        condition:
          api.connected:
            # state_subscription_only: true
        then:
          - esp32_ble_tracker.start_scan:
              continuous: true
          - delay: 1s
          - script.execute: send_mqtt_status
wifi:
  ssid: !secret wifi_ssid
  power_save_mode: none
  fast_connect: true
  # passive_scan: true
  reboot_timeout: 0s  # Never reboot
  on_connect:
    - script.execute: led_connected
  output_power: 18.5dBm
  on_disconnect:
    then:
      - esp32_ble_tracker.stop_scan:
      - delay: 10s
      - if:
          condition:
            and:
              - not:
                  wifi.connected:
              - not:
                  binary_sensor.is_on: wifi_ap_active
          then:
            - script.execute: led_ready
  ap:
    password: "QGg4ajvG9juq"
    channel: 6
    ap_timeout: 0s
# Captive portal for WiFi configuration
captive_portal:
This is the WiFi login request window (page 192.168.4.1):
But if you disable the captive portal then the wifi credentials needs to be hard coded in the yaml (?)
Hi @Hellis81
My goal is to have the WiFi information (hardcoded) not encrypted in a YAML file. I want to keep the firmware in its raw form so that the phone app can automatically configure the WiFi operation.
The Workflow:
  1. The ESP32-S3 enters AP mode (no internet).
  2. My mobile app connects to this AP.
  3. The app calls a custom API endpoint on the ESP32 to send the SSID and Password.
The Friction: Currently, using the captive_portal: component triggers an OS-level ‘Sign-in to Wi-Fi’ popup immediately upon connection. This popup interrupts the app’s internal onboarding flow and forces the user to wait about 20 seconds before the API call can successfully go through.
I’m happy to discuss this with you. Thanks !
Would the Web Server component solve your issue?
Would removing this achieve ypur goal?
Hi @huytran-df, did you manage to fix this in the end? I am running into the same problem now with my app. Works great on Android devices, but not on iOS.
