How to disable voice response once command execute
Not sure if someone knows how to do this, I installed a satellite with wyoming on a pi and everything works great. I would like to keep the default wakeword sound once detected, the sound command confirmation but disable the voice part where it confirms the action. For example, turn on the light, beep sound (wakeword activated), speak the command, beep sound (command accepted), voice confirmation (this is the part I want to remove). No more TTS at the end of the process. Thanks
