How to display an input select with all (or filtered) entities?
I’m wondering if there is how (by default or custom component) display an input select which enables the lovelace user select an entity.
For example, when you use the “Configure UI” option on the newest versions, you click to edit an entity card there are inputs which you can select the entity ids which will be displayed.
Example image:
52480941_2167568589996831_9026391487901859840_n
I would like to use a similar input on my lovelace template so I can select on runtime which entity is related to a specific automation for example.
Here’s something that i use for this.
