I am a little confused how HA works. I want to use a pi3 and elo touch screen to make a dashboard. I flashed a micro sd like and it loads the CLI with IP info. I am able to connect to it on my desktop to edit dashboards but how do I get the dashboard to appear on the touch screen? I cant figure out how to get past the command line.
If you used HA OS as installation method, there is no any graphic interface. It is a headless system.
You will have to use a separate Pi or PC with some regular OS and a browser on it.
Thank you!
