How to divide by 100 a MQTT value?
Hi guys,
I get a Temperature from my Arduino via MQTT.
The temperature is with 2 digits. So before sending it, I multiply the float value by 100.
Then I get the proper value in HA (something like 2203) when I check in the developper tool tab.
But on the lovelace interface I have 2.203 and I can’t do anything from the interface.
I’ve tried to find out how to make a calculation using templates, but I think I don’t know good enough HA to understand where to search the suitable solution.
The entity is called “sensor.1wire_03” and my sensors.yaml look like that:
  - platform: mqtt
    state_topic: "home-assistant/sensor01/1Wire_03"
    unit_of_measurement: "°C"
    value_template: '{{ value | round(2) }}'
    #state: '{{ (states("sensor.1wire_03") | float / 100) | round(2) }}'
If you could help, it would be really appreciated :slight_smile:
Thanks in advance.
David
Try
value_template: {{ ((states('sensor.1wire_03')|float)/100)|round(2) }}
 - platform: mqtt
    state_topic: 'home-assistant/sensor01'
    value_template: "{{ value_json.1Wire_03 | float/100 |round(2) }}"
I think you might need to adjust whole mqtt
Hi mate,
I got it doing this :+1::
  - platform: mqtt
    state_topic: "home-assistant/sensor01/1Wire_10"
    value_template: "{{ value | multiply(0.01) | round(2) }}"
Good. There’s nothing as satisfying as working it out yourself. :+1:
