This works:
Struggling with how to do “not in group” instead of “in group.” Is it possible or should I just do a function?
This works:
You could probably pass this list into another “get entities” node that did “not in”, but that sounds ugly, so maybe a function would be better.
FWIW I did what you’re after by using customizations rather than groups. An advantage of this approach is you can use “customize_domain.yaml” and “customize_glob.yaml” to ignore multiple entities in one hit. For example, in customize_glob:
"light.lily_*":
ignore_unavailability: true
Or individual entities in “customize.yaml”, such as:
sensor.michaels_apple_watch_battery_state:
Then the “get entities” node uses JSONata (which does not use ‘property’) with a value of:
$not( $entity().attributes.ignore_unavailability = true )
I found that I had to code it ‘backwards’ like this because using “= false” failed for entities without the attribute specified (which was all the ones I wanted to include).
A disadvantage of customizations is each entity needs to receive a state change for the customization to be picked up. You can also call “home_assistant.update_entity”. Alternatively, a restart of HA works for most, but not all.
Thanks for the customization suggestion. I’ll take a look at this.
