I am remodelling my son’s room and need your advice on how to manage a group of lamps with a wall switch.
What I had before:
- three standard lamps with a Sonoff Basic to drive them (so the maps were always ‘mechanically on’, and the power was provided by entities such as
switch.michael_standing
that was linked to that Sonoff relay) - an RF433 switch that was sending one single signal “I was pressed”, though a Sonoff RF bridge - there was a HA event fired then
- an automation that said “if the RF433 switch is pressed, then toggle the group of lamps”
What I have now:
- the same lamps with their Sonoff relay
- instead of the RF433, a Zigbee wall switch (powered) that has two states:
on
andoff
. It does not switch anything, just sends its state to HA
What I would like to achieve: to bind the state of the wall switch with the state of the group of lamps. It means that I could switch all lights on and off with the wall switch, and individual lamps through the UI - and that would also change the state of the wall switch.
Is that possible natively in HA?
The workaround I think I will use in the meantime is to have an automation doing the bind (aligning the state of the group with the state of the lamp)
