How to dynamically change the color of a Home Assistant tank based on an input_select using card_mod/level_color?
I am trying to dynamically change the background color of a tank in my Home Assistant dashboard based on a manually selected color via an input_select.
The input_select is defined in configuration.yaml as follows:
input_select:
  deposito_color:
    options:
      - red
      - green
      - blue
      - orange
      - yellow
      - purple
      - cyan
      - gray
      - white
      - black
I created a template sensor that converts the selected option into a CSS-compatible value. I have tried multiple configurations:
Option 1: using rgb() format
    sensors:
      color_deposito_rgb:
        friendly_name: "Tank Color RGB"
        value_template: >-
          {% set color = states('input_select.deposito_color') | default('orange') %}
          {% if color == 'red' %}rgb(255,0,0)
          {% elif color == 'green' %}rgb(0,255,0)
          {% elif color == 'blue' %}rgb(0,0,255)
          {% elif color == 'orange' %}rgb(255,165,0)
          {% elif color == 'yellow' %}rgb(255,255,0)
          {% elif color == 'purple' %}rgb(128,0,128)
          {% elif color == 'cyan' %}rgb(0,255,255)
          {% elif color == 'gray' %}rgb(128,128,128)
          {% elif color == 'white' %}rgb(255,255,255)
          {% elif color == 'black' %}rgb(0,0,0)
          {% else %}rgb(155,155,0)
          {% endif %}
Option 2: using HEX format:
    sensors:
      color_deposito_rgb:
        value_template: >-
          {% if color == 'red' %}#FF0000
          {% elif color == 'green' %}#00FF00
          {% elif color == 'blue' %}#0000FF
          {% elif color == 'orange' %}#FFA500
          {% elif color == 'yellow' %}#FFFF00
          {% elif color == 'purple' %}#800080
          {% elif color == 'cyan' %}#00FFFF
          {% elif color == 'gray' %}#808080
          {% elif color == 'white' %}#FFFFFF
          {% elif color == 'black' %}#000000
          {% else %}#9B9B00
          {% endif %}
In both cases, the sensor itself works correctly: for example, if “orange” is selected, the state returns rgb(255,165,0) or #FFA500.
However, when I attempt to use this sensor in my card via card_mod and level_color, it always displays the default color, regardless of the selected color:
card_mod:
  style: |
    ha-card {
      background-color: [[[
        return hass.states["sensor.color_deposito_rgb"].state || "rgb(155,155,0)";
level_color: |
full_value: "100"
No matter which color I select in the input_select, the tank always appears in the default color.
Question:
What format should the sensor return (rgb(...), #HEX, [R,G,B]) for card_mod and level_color to correctly interpret it?
Am I incorrectly accessing the sensor state in the card template?
Any advice on how to make the tank dynamically reflect the chosen color would be greatly appreciated.
Im using the fluid-level-background-card` library, and I’m not sure if that might be why the colors aren’t being picked up correctly.
