How to easily remesh Aqara Zigbee sensor
Hi
I just realized that Aqara sensors can easily be remeshed by following this procedure
  1. Select add new device in Home assistant
  2. Press the reset-button on the Aqara device for at least 3 seconds, until the blue LED flashed, then release
The Aqara device will no “re-attach” as the same device as before, but, if possible via another zigbee unit.
This worked nicely with deConz, that I am running in my installation.
I looked around quite a bit about how to re-mesh, but did not find any info to do it this easy way.
