I am pretty sure there has to be a simple way to do this but I was not yet able to. I am starting to play with blueprints (awesome feature!!) but I am not able to add custom new ones or edit existing ones.
I can add a blueprint via the UI and a link. If I just put a yaml file into the /config/blueprints/ folder and reload Home Assistant they don’t show up in the UI. The one I added via the UI also does not show up in this folder.
What is the proper way to edit downloaded blueprints and add custom new ones? Thanks in advance
