Pretty new here. Installed the hass.io on my pi2 according to https://home-assistant.io/getting-started/. Then it boots up with a solid HA screen. no command line access? I can access the web but still could not edit the configure yaml.
You need to ssh into the RPi in order to edit your configs. First, you’ll need to install the SSH add on through the Hassio menu on the left.
Thank you so much. I’ve used the puttygen to generate the key and entered the key value. However, when I try to connect using putty, it says disconnected: no supported authentication methods available (server sent: publickey, keyboard-interactive)
