How to enable and use FritzBox Tools Parental Control?
Hi there,
I am currently working on an automation for studying. It sets the volume, starts music, sets the light and I want it to activate an Internet Filter Blacklist on my FritzBox Router, so that I can’t access Youtube/Reddit etc.
The Original FritzBox Tools documentation states, that I have to add the names to “profile_list”.
The current official Fritz Box Tools Doc says, that Parental Control Switches “are disabled by default. You need to enable the wanted entities manually.”
I do not find the disabled Entities, nor do I find a different solution. What am I missing?
How do I activate the “Study” Profile (“Zugangsprofil”) for a specific device in an Automation?
Thanks a lot in advance :slight_smile:
I think I found my problem. It does not activate specific Parental controls as I thought. It simply turns off internet entirely for a device. :confused:
But at least I know what the problem has been. :slight_smile:
I also would love to switch profiles via automation (specifically my block youtube profile ;-D). Did you find a way to do this?
I think a device can only be assigned to one profile at a time. So it would be ideal to have a profile select list entity for each device. If this is not possible, we could make a feature request. :slight_smile:
Hi, unfortunately I never figured it out. I talked to the developer of the integration and apparently it doesn’t work. I don’t understand, since It’s been a feature in a previous version according to screenshots.
You can read a bit of the thread I had on github if that helps you, but unfortunately it never worked for me. Currently I’m working on a new server and want to use Adguard instead for this :slight_smile:
FRITZ!Box Tools won’t show me profiles to switch · Issue #76014 · home-assistant/core · GitHub
I was looking for this functionality as well and didn’t find anything which worked in HA, so I’ve create a small custom component for setting the device profiles myself. Effectively it remote-controls the FRITZ!Box frontend, but as of now this is the only way to select an access profile for a given device (it’s neither exposed in the HTTP-REST-API nor via TR-046) and for me it get’s the job done.
Feel free to check it out: GitHub - mithomas/ha-fritzprofiles: Switch your FRITZ!Box device access profiles from Home Assistant.
@mib1185: Maybe you could link that to the issues FRITZ!Box Tools won't show me profiles to switch · Issue #76014 · home-assistant/core · GitHub and More information about Profile Switches needed · Issue #23590 · home-assistant/home-assistant.io · GitHub ? Those were the ones I came across when I was looking for this functionality, maybe others do too and they are locked to contributors so I can’t comment myself.
Hi there @mithomas
I can’t believe there is finally a great option for this. It works great, thank you very much! Great job, really. This makes me a lot more productive during the day :slight_smile:
