How to enable power consumption statistics
Ok I changed the value of the last_reset to
2021-08-09T11:47:23.862268+00:00
and now it works
Hello, I am also struggling with this… would you be so kind and share code that you have in customization file.
Thank you in advance
I solved by changing the value of last_reset
Hi, how do I reset stats on a zigbee plug? The sensor does not have a last_reset parameter. Thanks.
Would it be possible to make an anergy measuring template from the time a bulb is on, knowing that the bulb is consumming 5Wh ?
Look at powercalc, it does exactly that and more.
Thanks for this info
Hi!
Thanks for the help provided here.
I was able to get the template sensors running for total power and total energy.
My PV setup contains two SMA 3-phase inverters and the SMA integration unfortunately does not provide the sum of all inverters for the current power and the total energy generated so far.
Here is my config:
template:
  - sensor:
      - name: "PV Total Power"
        unique_id: "sensor.pv_total_power"
        unit_of_measurement: "W"
        state: "{{ states('sensor.grid_power') |float + states('sensor.grid_power_2') | float }}"
        state_class: measurement
        device_class: power
      - name: "PV Total Energy"
        unique_id: "sensor.pv_total_energy"
        unit_of_measurement: "kWh"
        state: "{{ states('sensor.total_yield') |float + states('sensor.total_yield_2') | float }}"
        state_class: total_increasing
        device_class: energy
        attributes:
          last_reset: '1970-01-01T00:00:00+00:00'
After reading all off the topic i am to struggeling to get the power consuption statistics working. I have a ESP8266 reading the optical port en writing this to MQTT. The sensor is showing and providing the correct values:
  - platform: mqtt
    state_topic: "iot/smartmeter/sensor/1/obis/1-0:1.8.0/255/value"
    unit_of_measurement: 'kWh'
    last_reset_topic: "iot/smartmeter/sensor/1/obis/1-0:1.8.0/255/value"
    last_reset_value_template: '2021-08-09T11:47:23.862268+00:00'
The sensor is not selectable for the statistics. Any help is welcome :smiley:
Hi @elik745i, Can I please ask how you fixed the unit_of_measurement showing as kwhh please? I have left mine running for over an hour and it still shows kwhh which stops it logging energy data.
OK so I’m not sure what the original problem was but I sorted it by deleting the original sensor and recreating it with a slightly different name and it now shows as kWh.
Don’t know what changed, but since a while my solar used energy doesn’t show in the Energy dashboard:
The supplying sensor does work however:
Anyone an idea?
Im having the same issue. Nothing changed it just stopped showing up on the graph.
I have double checked the sensor and the config and it seems to be configured correctly.
Hi I have a similar problem as many above.
I have a smart home hub which allows me to connect, among money others, z-wave devices to it. I have a smart plug with power and energy measurement connected to it. I do not have a Z-wave dongle for my HA setup.
I can expose the device and its 3 entities to HA using MQTT. This lets me turn it on/of, read out the power and energy use. I would like to add the reading from this device to the energy dashboard but it does not appear on the list of entities. I can however add it as a card to my other dashboards and get correct readings.
Is there any way around it? I understand that HA cannot track statistics for this entity as per: Expected data source not listed - Home Assistant but can I do anything about it?
I tried adding this to my configuration.yaml but it did not work out. I read that there is a new configuration format for templates and I gave that a try as well but with no success.
  sensors:
    power_meter_energy:
        friendly_name: "power meter energy"
        last_reset: none
Hello everyone,
I tried to reproduce the same exact sensor but I had no luck in allowing home assistant to use it as a grid consumption source.
This is my sensor definition:
template:
  - sensor:
    - name: "house_energy_kwh"
      state: "{{ states('sensor.house_statistics_instant_total') }}"
      attributes:
