I just installed hassio on my raspberry pi 3 b (install version 1.9) using etcher. Every video shows that you can just ssh into the raspberry, but i can not. As far as i can tell, there is even no real terminal client with a keyboard attached.
How can i install components or at lest just edit the configuration files using an web-browsing interface. As far as i can see, there is no place to edit the configuration files.
flamingm0e:
Then please refer me to the correct documentation, because i canāt find it. I can find lots of documentation of which settings to have, but there is no documentation on HOW to install the add-on!
If you select the three horizontal bar icon in the upper left, then Hass.io, and you get a blank, white screen, Iād guess your installation has a problem.
Have you tried to reset? Maybe even a hard power cycle, and see if that helps.
Thanks flamingm0e: This was due to the fact, that I used this site documentation and the links to the page on ssh and samba⦠which tells NOTHING about how to install the add-on. That was so f***** frustrating.
