Is it possible to get an enumeration of all entities of one integration? For example all entities that are part of the SmartThings integration?
If you go to the integrations page any of them configured thru the UI will be there and list the devices and entities associated with them
I suspect he wants programmatically.
well, then no.
at least not something built-in that I know of.
Unless the entities have an attribute that is only present for entities created by the SmartThings integration, there’s nothing available (for templating) to select them.
I don’t use the SmartThings integration but I’ll take a guess it doesn’t add an identifying attribute to its entities (few if any integrations do this) so there’s nothing available for a template to select.
You could manually add a custom attribute to each one (via Customizations) and then the template can select all entities with the custom attribute. However, that’s a purely manual, not automatic method (i.e. if the SmartThings integration discovers and includes another entity, you will have to manually add your custom attribute to the new entity).
EDIT There’s a way to do it and petro shows how below.
EDIT: device_entities() only exists in 2021.10.0+ or the current beta. So you’ll need to be on the latest.
You can only find entities in an integration if the integration is implemented through the ui. But first, you’ll need to find the integration identifier. Then use that identifier to list the entities.
Here’s a template that will find you the identifiers for each integration that’s implemented in the UI.
{% set devices = states | map(attribute='entity_id') | map('device_id') | unique | reject('eq',None) | list %}
{%- set ns = namespace(integrations = []) %}
{%- for device in devices %}
{%- set ids = device_attr(device, 'identifiers') | list | first %}
{%- if ids and ids | length == 2 %}
{%- set integration, something_unique = ids %}
{%- if integration not in ns.integrations %}
{%- set ns.integrations = ns.integrations + [ integration ] %}
{%- endif %}
{%- endif %}
{%- endfor %}
{{ ns.integrations }}
If the integration you desire is not listed in the output, then you cannot get the list of entities.
e.g.
Then, take a listed integration and paste it into the following tempalte. For example, I’m pulling hyperion entities.
{%- set find_integration = 'hyperion' %}
{%- set devices = states | map(attribute='entity_id') | map('device_id') | unique | reject('eq',None) | list %}
{%- set ns = namespace(entities = []) %}
{%- if ids and ids | length == 2 and ids[0] == find_integration %}
{%- set ns.entities = ns.entities + device_entities(device) %}
{%- endif %}
{%- endfor %}
{{ ns.entities }}
e.g.
EDIT2: If you don’t want to wait for 2021.10, this will work currently:
{% set entities = states | map(attribute='entity_id') | list %}
{%- for entity_id in entities %}
{%- set ids = device_attr(entity_id, 'identifiers') %}
{%- if ids %}
{%- set ids = ids | list | first %}
{%- set ns.entities = ns.entities + [ entity_id ] %}
{%- endif %}
{%- endif %}
{%- endfor %}
{{ ns.entities }}
EDIT3: 1 liner in current version of HA for list of UI integrations:
{{ states | map(attribute='entity_id') | map('device_id') | reject('eq',None) | map('device_attr', 'identifiers') | map('list') | map(attribute='0') | map('list') | reject('eq', []) | map(attribute='0') | unique | sort }}
Very nice work (and I’ll amend my post above)!
FYI
device_entities exists in 2021.9.7 and I can confirm your example containing it does in fact work with it.
From here:
huh, I thought it was skipped in the beta this month
Maybe I’m remember a different macro
Got to say that this made me do a double-take. device_id is a filter?!? Why yes, yes it is.
FWIW, I had taken notice of area_id and area_name but skimmed over the device-related ones. Looks like I need to review them because it opens new doors for templating.
Yah, it does but it also doesn’t make it easy. For loops and/or namespace are pretty much required at all times.
Also, here’s a zwave one that’s pretty useful
Thanks for the link! I swapped zwavejs with upb and it cranked out a table listing my UPB entities.
Yes, there is! This should give you a list of entities belonging to the SmartThings integration:
{{ integration_entities('smartthings') }}
Changed to lowercase. It appears some integrations will accept the upper, but the lower seems to work with most if not all integrations. Although for some strange reason, “Sonos” returned a larger list than “sonos”.
I think it should be lowercase, ie
Very good, I will amend my post to reflect that.
I did some more digging and it turns out the Sonos example I had based my reply on was a fluke. For a proper list of integration identifiers, I suggest you check out petro’s post:
They all appear to be lowercase, as nickrout pointed out (heh, I’m a poet). Helpful in case the integration name in the UI does not match the actual integration identifier (e.g. Steam = steam_online)
Hi guys.
What if I want to filter specific type of entity? I want to get all switches on my Google wifi to block internet access for a period of time. I get all swtiches and trackers using:
{%- set devices = states.switch | map(attribute='entity_id') | map('device_id') | unique | reject('eq',None) | list %}
Im stuck in how to put all that in a group so I can switch it on and off
You can’t send a list of device_id’s to any service. You have to use the entity_id. Also, the only way to create dynamic groups is by using group.set but keep in mind, that is a legacy group and it’s functions are limited.
It’s probably best if you just make a switch group instead.
Hi all,
strange but I don’t get ANY output from the template.
Of course I have plenty of integrations set up by UI.
The only output I get when pasting the template into the UI is
UndefinedError: No first item, sequence was empty.
Any help would be appreciated
you either:
- don’t have devices for the integration
- spelled the integration incorrectly.
