I have an entity (switch.heartbeat) that changes state very frequently and it is flooding my database.
Already attempted to exclude it by inserting these statements into configuration.yaml but I still see the related entries into the database table events.
recorder:
purge_keep_days: 5
db_url: !secret db_url
include:
entities:
- some
- entities
exclude:
entities:
- switch.heartbeat
history:
exclude:
entities:
- switch.heartbeat
logbook:
exclude:
entities:
- switch.heartbeat
Mine doesn’t look any different than yours.
Are you sure, the name for the sensor is correct? Or could it be, that you see your old entries in the db? They won’t get deleted automatically if you change the configuration.yaml
to exclude something.
I assume you did restart HA after your changes.
rccoleman
(Rob Coleman)
June 29, 2021, 8:48pm
3
The old entries will remain in the database even after you exclude it, which only affects new entries. You can use recorder.purge_entities
to purge the historical data.
Thanks for the replies.
The entity name is correct, I did restart HA, and I know that old db rows do not get deleted.
This switch is triggered by an automation, not sure if this makes any difference.
Here below are some db rows related to this switch.
MariaDB [homeassistant]> select * from events order by time_fired desc limit 10;
| event_id | event_type | event_data | origin | time_fired | created | context_id | context_user_id | context_parent_id |
| 2389065 | call_service | {"domain": "switch", "service": "toggle", "service_data": {"entity_id": ["switch.heartbeat"]}} | LOCAL | 2021-06-30 04:59:41.012457 | 2021-06-30 04:59:41.012457 | 401e044287209a9337cbd7891cb8b576 | NULL | NULL |
| 2389063 | call_service | {"domain": "switch", "service": "toggle", "service_data": {"entity_id": ["switch.heartbeat"]}} | LOCAL | 2021-06-30 04:59:40.012826 | 2021-06-30 04:59:40.012826 | eaca56e5f9e8127692a03a39b0d3128f | NULL | NULL |
| 2389061 | call_service | {"domain": "switch", "service": "toggle", "service_data": {"entity_id": ["switch.heartbeat"]}} | LOCAL | 2021-06-30 04:59:39.011834 | 2021-06-30 04:59:39.011834 | b0e80022ca428ed67dfcdcb7a7f3af5e | NULL | NULL |
| 2389059 | call_service | {"domain": "switch", "service": "toggle", "service_data": {"entity_id": ["switch.heartbeat"]}} | LOCAL | 2021-06-30 04:59:38.012059 | 2021-06-30 04:59:38.012059 | 8f848d4d37a11f6f59228814894f4103 | NULL | NULL |
| 2389057 | call_service | {"domain": "switch", "service": "toggle", "service_data": {"entity_id": ["switch.heartbeat"]}} | LOCAL | 2021-06-30 04:59:37.019648 | 2021-06-30 04:59:37.019648 | 6194190ca76245aa6e608a4a6ed6bc5c | NULL | NULL |
| 2389055 | call_service | {"domain": "switch", "service": "toggle", "service_data": {"entity_id": ["switch.heartbeat"]}} | LOCAL | 2021-06-30 04:59:36.015049 | 2021-06-30 04:59:36.015049 | 8b4be3b67d909d7fdb0caf130cca05d7 | NULL | NULL |
| 2389053 | call_service | {"domain": "switch", "service": "toggle", "service_data": {"entity_id": ["switch.heartbeat"]}} | LOCAL | 2021-06-30 04:59:35.014805 | 2021-06-30 04:59:35.014805 | 26283c503ad3dd899cdbd47eac77eab5 | NULL | NULL |
| 2389051 | call_service | {"domain": "switch", "service": "toggle", "service_data": {"entity_id": ["switch.heartbeat"]}} | LOCAL | 2021-06-30 04:59:34.012122 | 2021-06-30 04:59:34.012122 | f87c5841ad2dfd856fad2641a17a0f7e | NULL | NULL |
| 2389049 | call_service | {"domain": "switch", "service": "toggle", "service_data": {"entity_id": ["switch.heartbeat"]}} | LOCAL | 2021-06-30 04:59:33.015483 | 2021-06-30 04:59:33.015483 | cf7089247bb2fbe3904534679d65c16c | NULL | NULL |
| 2389047 | call_service | {"domain": "switch", "service": "toggle", "service_data": {"entity_id": ["switch.heartbeat"]}} | LOCAL | 2021-06-30 04:59:32.012708 | 2021-06-30 04:59:32.012708 | 99b6ce7799f3472992e25806b1c8ef49 | NULL | NULL |
10 rows in set (0.002 sec)
koying
(Chris B)
June 30, 2021, 5:42am
5
Not 100% sure, but I think that excluding entities from the recorder will only prevent state changes to be recorded, i.e. event_type = "state_changed"
You could exclude call_service
from being recorded with
recorder:
exclude:
event_types:
- call_service # Don't record service calls
That did the trick!
Thanks a lot koying
