Hi all,
Im having difficulty in excluding the wizlight component (installed using HACS) from the logger.
I’ve excluded the following but had no luck. Can anyone please let me know what I’m missing.
Thank you
2020-11-17 09:02:01 ERROR (MainThread) [pywizlight.bulb] [wizlight 192.168.1.131, connid 390a8523765b90] Failed to do UDP call(s) to wiz light
2020-11-17 09:02:01 ERROR (MainThread) [pywizlight.bulb] [wizlight 192.168.1.132, connid 390a8523765fbc] Failed to do UDP call(s) to wiz light
2020-11-17 09:02:01 ERROR (MainThread) [pywizlight.bulb] [wizlight 192.168.1.133, connid 390a852376627a] Failed to do UDP call(s) to wiz light
2020-11-17 09:02:01 ERROR (MainThread) [pywizlight.bulb] [wizlight 192.168.1.134, connid 390a8523766504] Failed to do UDP call(s) to wiz light
2020-11-17 09:02:01 ERROR (MainThread) [pywizlight.bulb] [wizlight 192.168.1.126, connid 390a852376756c] Failed to do UDP call(s) to wiz light
2020-11-17 09:02:01 ERROR (MainThread) [pywizlight.bulb] [wizlight 192.168.1.127, connid 390a85237677bc] Failed to do UDP call(s) to wiz light
My configuration.yaml:
logger:
default: warning
logs:
custom_components.wiz_light: critical
custom_components.pywizlight: critical
custom_components.pywizlight.bulb: critical
homeassistant.helpers.entity: critical
homeassistant.components.wiz_light: critical
homeassistant.components.pywizlight: critical
homeassistant.components.pywizlight.bulb: critical
The component was installed by HACS
What am I missing?
Thanks in advance!
