Hi, I set up an WiFi connection with
nmcli c add type wifi con-name <connect name> ifname wlan0 ssid <ssid>
nmcli con modify <connect name> wifi-sec.key-mgmt wpa-psk
nmcli con modify <connect name> wifi-sec.psk <password>
nmcli con up <connect name>
The problem is after every startup I need to use the
command. So I wanted to make a script which Home Assistant uses at startup so it connects automatically to the network at startup. But how do I make a script like this?
