I have a project where I need to start and stop a script from within a lambda. Has anyone found a clean way to do this? I’ve tried something like this but it fails to compile:
script:
- id: script_timer
mode: restart # Restarts the timer if called again while already running.
then:
... do stuff...
text_sensor:
lambda: |-
...other code...
id(script_timer).execute; // Start script_timer
...more code...
Fails to compile with error:
error: invalid use of non-static member function ‘virtual void esphome::script::RestartScript::execute()’
Looking at main.cpp it appears there are various global objects created under the hood to manage the starting and stopping of scripts so it doesn’t look like being a simple thing to do.
For the time being, as a work-around, I’ve created a dummy internal switch which proxies the the starting and stopping of the timer script:
script:
- id: script_timer
then:
... do stuff...
switch:
# Dummy internal switch to control script_timer from lambda:
internal: true # Not published to HA.
turn_on_action:
- script.execute: script_timer
turn_off_action:
- script.stop: script_timer
text_sensor:
lambda: |-
...other code...
id(switch_timer).turn_on(); // Start script_timer via dummy switch.
...more code...
id(switch_timer).turn_off(); // Stop script_timer via dummy switch.
This works, but it’s not ideal. I’d prefer to start and stop the script directly from the lambda if any one knows how…? Thanks.
