How to extend an entity configuration?
Home Assistant is becoming at home a core service to define entities, which are then acted upon via AppDaemon, the UI, …
The problem I am facing is that the description (of a light for instance) is very restrictive, I cannot add any extra field except the ones specifically defined in the light entity (name, platform, state_topic, …). I would like to add emements such as room, rf_signal, etc. - which I would query (for instance from AppDaemon).
Is there a way to extend the list of allowed fields for an entity?
If I need to expand the code (say, by creating a new class which inherits from a base one) this is OK as soon as I can keep this code in parallel to the official one (i.e. - not forking HA)
Put it in the entity_id. For example I have sensor type and location in mine:
sensor.dht_lounge_temperature
binary_sensor.pir_lounge
