I want to put some sensors outside of the existing WiFi range. Whats the simplest way of doing this so that I can still interact with the sensor from my Pi running HassIo?
Many thanks in advance for any thoughts on this,
Mark
Mark
You would need a Wi-Fi solution. A Z-Wave mesh network can have a much further reach.
I think Zigbee mesh can also reach further .
Zigbee, Z-Wave, & Wi-Fi all need sevices designed to use them though. You can get different radio options for these on the Pi. I have a USB stick that does both Zigbee & Z-Wave.
Thanks @anon34565116
Do you know if the Pi with Hass.io can handle handle WiFi and Z-Wave at the same time?
My RPi 3B+ has internal Wi-Fi and I have my USB stick plugged into one of the 4 USB ports. It works fine with Home Assistant. It should work with Hassio too. I chose to use my Ethernet connection instead of Wi-Fi but either would work.
Thanks @anon34565116 I think I get it now: The z-Wave uses the USB stick to communicate with the z-Wace components when its not using the inbuilt wifi for the wifi components.
I’m also going to look at a wifi mesh too as another option to extend the reach of the system.
z-wave certainly sounds interesting.
Thanks again,
Mark
Here is what I bought that does both. I have not tested Zigbee though.
https://www.amazon.com/gp/product/B0157GOEA8/
Also Z-Wave compatibility is better that Z-Wave. Some Z-Wave devices still need they own hub
Sorry @anon34565116 You lost me there! is “Z-Wave Compatibility” different from “Z-Wave” ?
Thanks for the link to the USB hub you bought that really helps.
I mean that just because it is a Zigbee device, that does not mean it can communicate properly with your Zigbee card in your server. For instance, if you buy Hue Zigbee lights, you usually need a Hue hub to talk to them.
Z-Wave is more like Wi-Fi. The standard specifies how the devices must communicate with each other, regardless of brand. A Dell Wi-Fi computer cam talk to a Linksys router with no issues because they both follow the Wi-Fi standard.
Sorry to confuse things.
The option I bought is for the US. Other countries have different Z-Wave frequencies.
Another Z-Wave option for the Raspberry Pi could be a Razberry Board. You lose Bluetooth though.
https://www.amazon.com/Z-Wave-Me-RaZberry2-Plug-Raspberry-frequency/dp/B01M3Q764U
