How to extend the topology via WiFi
I installed Home Assistant docker version on a Synology 220+ DSM6.2 and successfully attached a SONOFF ZB Dongle-E USB Dongle Plus as coordinator (or gateway?) that sees two SONOFF SNZB-02 sensor temperature devices in the same building.
As I want to extend this network to an adjacent building, I am wondering if using the SONOFF ZB Bridge Pro would work for this purpose: to act as a local Zigbee collector/gateway, then forward data via WiFi to HA? If all ZB data have to be collected via the ZB Dongle antenna then I assume my plan is not good, so I need other suggestions. The adjacent building does not have main power, only a car battery + solar panel, so plan is to provide a 5V supply to the ZB Bridge-P.
Many thanks!
