How to extract from nested JSON in json_attributes_path and json_attributes
Can someone help me extract from this JSON?
I can get JSON but cannot set to json_attributes :frowning:
I cannot get all JSON value to sensor value by 255 character limits.
API has limit about max 30 requests / 5 min.
I want to save the number of API requests.
then I want to make a single sensor and it has six attributes.
sensor's value: "Remo E lite" (anything)
attribute[0]:
                    "name": "coefficient",
                    "epc": 211,
                    "val": "1",
                    "updated_at": "2020-08-21T13:23:44Z"
attribute[1]:
                    "name": "cumulative_electric_energy_effective_digits",
                    "epc": 215,
                    "val": "6",
attribute[3....
JSON sample
        "id": "632603e4-e0f8-4073-9034-77f8b19e9128",
        "device": {
            "name": "Remo E lite",
            "id": "79b6fea9-65f6-42f3-aa38-ddcd041aa1b6",
            "created_at": "2020-04-27T09:22:43Z",
            "updated_at": "2020-08-15T11:13:23Z",
            "mac_address": "f4:cf:a2:81:03:94",
            "bt_mac_address": "f4:cf:a2:81:03:96",
            "serial_number": "4W120040000338",
            "firmware_version": "Remo-E-lite/1.1.5",
            "temperature_offset": 0,
            "humidity_offset": 0
        "model": {
            "id": "7f3de26b-0afa-44fe-8680-7cf67f8bd415",
            "manufacturer": "",
            "name": "Smart Meter",
            "image": "ico_smartmeter"
        "type": "EL_SMART_METER",
        "image": "ico_smartmeter",
        "settings": null,
        "aircon": null,
        "signals": [],
        "smart_meter": {
            "echonetlite_properties": [
                    "epc": 211,
                    "val": "1",
                    "epc": 215,
                    "val": "6",
                    "name": "normal_direction_cumulative_electric_energy",
                    "epc": 224,
                    "val": "137351",
                    "name": "cumulative_electric_energy_unit",
                    "epc": 225,
                    "val": "1",
                    "name": "reverse_direction_cumulative_electric_energy",
                    "epc": 227,
                    "val": "27",
                    "name": "measured_instantaneous",
                    "epc": 231,
                    "val": "778",
I tried this
  - platform: rest
    resource: https://api.nature.global/1/appliances/
    value_template: '{{value_json[0].device.name}}'
    json_attributes_path: "$..echonetlite_properties"
    json_attributes:
      - "$.[2]"
    headers:
      Authorization: !secret nature_key
    scan_interval: 60
    force_update: true
    json_attributes_path: "$..echonetlite_properties.*"
    json_attributes:
      - [0]
Anyone can help me?
  - platform: rest
    json_attributes_path: "$[0].smart_meter"
    json_attributes:
    - echonetlite_properties
Thank you to reply.
I tried this.
Then error occured below that.
Logger: homeassistant.components.rest.sensor
Source: components/rest/sensor.py:241
Integration: rest (documentation, issues)
First occurred: 13:37:42 (11 occurrences)
Last logged: 13:42:44
JSON result was not a dictionary or list with 0th element a dictionary
Then the posted JSON in your original post is not correct. You can use an online json path selector to play around with the paths. You can verify that the path I wrote works with the JSON you supplied in your original post.
