How to extract temperature from weather card?
I’m using the integrated weather forecast:
How would I extract the temperature value to be shown in a entity card?
Lookup your weather integration in Dev Tools/states
Auswahl_210
and create a template sensor from the attribute.
{{ state_attr('weather.dark_sky', 'temperature') }}
Thanks @VDRainer, but… still have problems.
First a maybe stupid question: What is the “dev-info panel for details”?
Because that’s the message I get with the entry in my sensors.yaml shown below.
The log shows
Invalid config for [sensor.template]: invalid slug weather.in_kolle_ze_hus (try weather_in_kolle_ze_hus) for dictionary value @ data['sensors']. Got OrderedDict([('weather.in_kolle_ze_hus', OrderedDict([('value_template', "{{ state_attr('weather.in_kolle_ze_hus', 'temperature') }")]))]). (See ?, line ?). Please check the docs at https://home-assistant.io/components/sensor.template/
sensors.yaml:
# Temperatur-Attribut als Extra-Wert
    sensors:
      weather.in_kolle_ze_hus:
        friendly_name: "HA Temperatur Vorhersage"
        unit_of_measurement: '°C'
        value_template: "{{ state_attr('weather.in_kolle_ze_hus', 'temperature') }}"
When I put weather_in_kolle_ze_hus instead, the syntax is okay, but I don’t get the values…
The problem is in the fourth line:
    sensors:
Remove weather. from that line and you’ll have sensor.in_kolle_ze_hus created:
    sensors:
      in_kolle_ze_hus:
Thanks @Tinkerer, @VDRainer. Got it to run :+1:
Here my working template to provide the complete solution:
    sensors:
      norwegian_temperature:
        friendly_name: "met.no Temperatur Vorhersage"
My idea is to figure out, which forecast fits best to my measured values.
Hi, thanks for your example, and how to read the condition, like “rainy” in your example? I tried to replace ‘temperature’ with ‘condition’ but I get None. And ‘forecast condition’?
EDIT, sorry it was
value_template: "{{ states('weather.homexxx') }}"
I’m not sure I understand, you posted a question.
VDRainer gave you 85% of what you needed
Tinkerer then came back and corrected your syntax (say another 10%)
Then you say “you” solved it ?
Good way of giving credit where its due and encouraging others to help you in the future :crazy_face:
Thanks Mutt for your remark:
If understand correct, you are complaining that I collect credits for things I haven’t solved by my own?
To be honest, beside the fact that this is totally of topic, I don’t care about those medals, but I have pity on people who aspire to it.
My idea was to summarize and complete the x% posts in one single post to make it more comfortable for other users without the need to read the whole thread!
@VDRainer, @Tinkerer: If one of you think it’s better to mark one of your post as solution, please tell me and of cause I will do so.
I don’t care. :peace_symbol:
Eh, your post has the final solution - which is what others who find this thread will want :wink:
I think I know what you whant, shomthing like this
weather-card/143260/5
    sensors:
      solar_angle:
        friendly_name: "Sun angle"
        unit_of_measurement: "degrees"
        value_template: "{{ state_attr('sun.sun', 'elevation') }}"
      sunrise:
        value_template: "{{ state_attr('sun.sun', 'next_rising') }}"
    sensors:
        value_template: "{{ state_attr('weather.hjem', 'temperature') }}"
      norwegian_weather:
        friendly_name: "met.no weather Vorhersage"
        value_template: "{{ states('weather.hjem') }}"
Hey,
I’d like to take benefit of this post.
I do not get created the sensor. Am I missing something?
  sensors:
    casita:
      friendly_name: "Temp"
      value_template: "{{ state_attr('weather.casita', 'temperature') }}"
Cheers&Thanks
In “config.yaml” this must be under “sensor” statement like :slight_smile:
       sensors:
        casita:
…, or if You have “!include sensor.yaml” in the beginning of config.yaml then You need to create, (or if You have one, edit it), with your statement.
here is my example in config.yaml:
  - platform: time_date
    display_options:
      - 'time'
      - 'date'
      - 'date_time'
      - 'date_time_utc'
      - 'date_time_iso'
      - 'time_date'
      - 'time_utc'
      - 'beat'
    sensors:
      wetemp:
        friendly_name: "temperatura_vani"
        value_template: "{{ state_attr('weather.dom', 'temperature') }}"
hoping someone can help me with very similar problem. I wish to extract the outside temperature (for the moment, the basic value from weather.home will do) , and record it (forever, give or take) so that I can graph it against heating requirements, etc.
I have a bunch of templates already defined and working with this kind of syntax
     sensors:
      zappi_garage_load_kw:
       unit_of_measurement: 'kW'
       value_template: "{{ ( states('sensor.myenergi_zappi_15606200_internal_load_ct1') | float / 1000)}}"
       friendly_name: "Zappi Garage Load"
(and lots more)
if I add a temperature one using this format like this:
   temp_outside:
         value_template: "{{ state_attr('weather.home','temperature') }}"
I can see its value correctly in History . but I can NOT see it in devtools->statistics, which is what I believe I need to be able to track it long term. Its my understanding that this
state_class: measurement
is required to be added to enable the long term tracking. If I add THAT line, the config for that template section becomes invalid. So then I read that there is a new way to do templates which has to be used to allow this so I have tried that format as well:
(obviously I removed the other one from config)
template:
     -sensor:
       - name: outside_temperature_internet
         friendly_name: "Outside Temperature Internet"
this a) passes config validation b) gives the expected numeric value corresponding to the actual temperature when pasted into devtools->templates editor. BUT when actually in use, gives a state of “unavailable” in devtools->states and no data in History.
this is driving me nuts going round in circles, can anyone help?
thanks
You can do this for the stats.
template:
  - sensor:
      - name: "Énergie heures chauffage premier"
        unit_of_measurement: "kWh"
        device_class: energy
        state: >-
          {% set a = state_attr("climate.sinope_thermostat_salon","daily_kwh") | float %}
          {% set b = state_attr("climate.sinope_thermostat_cuisine","daily_kwh") | float %}
          {% set c = state_attr("climate.sinope_thermostat_salle_deau","daily_kwh") | float %}
          {{ (a + b + c) | round(2) }}
And then add the sensor to a stats sensor.
  - platform: statistics
    unique_id: "energie_heures_chauffage_premier"
    name: "Statistiques heures chauffage premier"
    entity_id: sensor.energie_heures_chauffage_premier
    state_characteristic: mean
    sampling_size: 20
    max_age:
      hours: 24
thanks but your method doesn’t fix it for me . the problem seems to me that with the
template:
  - sensor:
etc...
method, which you also used, then in my case I get unavailable for the newly created item
my config as of now:
template:
    -sensor:
      - name: outside_temperature_internet2
        state: "{{ state_attr('weather.home','temperature') }}"
this yields the below: state exists but has nothing
with the
    sensors:
method, I can create a sensor and it has data, but I can’t track it… I don’t understand the difference (other than that I read one is newer)
Don’t forget to set device_class: temperature to get the right icon automatically
    sensors:
Here are all the forecast details I capture in my own config:
    sensors:
      forecast_current_temperature:
        unique_id: forecast_current_temperature
        friendly_name: Outside temperature
        unit_of_measurement: °C
        value_template: "{{ state_attr('weather.forecast_home', 'temperature') }}"
      forecast_current_temperature_hourly: # testing to see if it gets more freq updates
        unique_id: forecast_current_temperature_hourly
        friendly_name: Outside temperature (hourly)
        value_template: "{{ state_attr('weather.forecast_home_hourly', 'temperature') }}"
      forecast_current_humidity:
        unique_id: forecast_current_humidity
        unit_of_measurement: "%"
        device_class: humidity
        value_template: "{{ state_attr('weather.forecast_home', 'humidity') }}"
      forecast_current_pressure:
        unique_id: forecast_current_pressure
        friendly_name: Outside air pressure
        unit_of_measurement: hPa
        device_class: pressure
        value_template: "{{ state_attr('weather.forecast_home', 'pressure') }}"
      forecast_current_wind_speed:
        unique_id: forecast_current_wind_speed
        friendly_name: Outside wind speed
        unit_of_measurement: km/h
        device_class: wind_speed
        value_template: "{{ state_attr('weather.forecast_home', 'wind_speed') }}"
      forecast_current_wind_bearing:
        unique_id: forecast_current_wind_bearing
        friendly_name: Outside wind bearing
        unit_of_measurement: "°"
        icon_template: mdi:compass
        # device_class: ???
        value_template: "{{ state_attr('weather.forecast_home', 'wind_bearing') }}"
How can I read templow?
Hi Hajo,
I am curious in your findings about which forecasts gave you the best prediction?
