Hi all,
Very much enjoying getting stuck into HA and I’ve recently been getting into the espHome stuff. I’ve got a esp8266 board running in the cellar which reads an ultrasonic sensor and controls a relay. I applied some filters to the sensor to remove the outliers which is working nicely. Here’s the code I’m using in espHome:
- platform: ultrasonic
trigger_pin: D6
echo_pin: D5
name: "Dehumid Tank Ultrasonic Sensor"
update_interval: 20s
accuracy_decimals: 4
filters:
- median:
window_size: 3
send_every: 3
send_first_at: 3
- lambda: |-
float MIN_VALUE = 0.05;
float MAX_VALUE = 0.4;
if (MIN_VALUE <= x && x <= MAX_VALUE) return x;
else return {};
- sliding_window_moving_average:
As I wanted to keep the ‘raw’ distance data coming into HA as well as monitoring the tank fill level I added a template sensor with this code:
template:
- sensor:
- name: "dehumid_tank_percentage"
unit_of_measurement: "%"
filters:
- lambda:
state: >
{% set range = states('sensor.dehumid_tank_ultrasonic_sensor') | float %}
{% set full = 0.05 | float %}
{% set empty = 0.4 | float %}
{{ ((empty - range) / (empty - full) * 100) | round(1) }}
The issue I have is that when the espHome gets an invalid reading it sends a null value to HA. When the template sensor updates, it reads this as zero and thus outputs a percentage fill of 114.3 %.
I’ve tried various things but how can I either return the previous value or send another null value from the template sensor?
Thanks!
James
