How to find out netatmo names
Hi!
With discovery, ha finds some sensors, unfortunately not the ones I want (I have connected stations from other houses to my account). And sometimes, the sensors don’t show up at all. The thermostat does. But if I try to configure it manually, it doesn’t how up either.
I have no idea how to configure with module names, station name etc.
Of course I know what they’re called, but it doesn’t work with ha. If the station is calles “Home Benissa” for example, what do I put for station: Home Benissa, “Home Benissa”, home_benissa…? neither works.
I’m having the same problem.
Did you manage to solve your problem? Any help would be a appreciated.
// Svein Erik
Hi!
In the end I just deleted the connection to the stations I don’t want in HA.
regarding the thermostat, the config looks like this now:
climate: platform: netatmo relay: Heizung Finca thermostat: - Thermostat friendly_name: Netatmo Thermostat
Thank’s for your quick replay :slight_smile:
I will do some small changes in my config file and see if I get lucky too…
// Svein Erik
