Simpel question : is it possible to search where an entity or script or even some string is used in HA ?
I guess it depends on how you edit your configuration files.
I write almost everything yaml and use Notepad++ as my text editor so itâs very easy to do a âfind in filesâ and enter the search string.
I would assume most text editors provide some sort of search capability and even UI configured code is written in plain text in the storage directory (even if it could be xml).
Sorry for my late reaction.
Let say I have a script âSwitch : Rolluikâ. This script has an entity name âscript.switch_rolluikâ.
Now I want f.e. to rename it to âaaa : Rolluikâ. I duplicate my old script and give it that name (and delete the old one). The new script has now an entity name âscript.aaa_rolluikâ.
With my text editor I open these files and do a find & replace :
- automatisations.yaml
- scripts.yaml
- templates.yaml
Other files (donât know where the dashboards are stored ?) ?
The example is a script, but it could also been a helper or other entity.
And my initial question was in fact if there was not a tool to do this for the whole HA files.
nothing built-in.
if you use the ui to manage your dashboards then those are all stored in the .storage folder files. And those files are not meant to be user editable. Iâm not aware of another way of doing it other than manually editing the dashboards.
Thatâs what I thought
But hey, if you donât ask, you donât win
Thank you !
