Getting issues with TTS when trying to upgrade. The docs mention this but don’t say how to fix. Another thread said to change google to google_translate in the tts section.
But if you do that you get this warning: Configuration invalidCHECK CONFIG
Platform not found: tts.google_translate
Is there a fix? I don’t mind disabling this if not.
Remove your tts config, save, restart and try the upgrade chaek again, if it passes go ahead with the upgrade. When done, change your tts config to this and restart:
