hello, everytime when i rebbot the raspberry pi, the Aeotec ZW090 Z-Stick Gen5 EU changed its path automaticaly from ACM0 to ACM1. so i have to change it in the configuration.yaml file.
Could someone tell me please how can i fix the path?
zwave: usb_path: /dev/ttyACM1 thanks
Do you find your device at /dev/serial/by-id/ ? Try to use that path.
/dev/serial/by-id/
so you mean that i have to configure it in the configuaration.yaml like that ls /dev/serial/by-id
usb-0658_0200-if00
zwave: usb_path: usb-0658_0200-if00
Right?
zwave: usb_path: /dev/serial/by-id/usb-0658_0200-if00
amazing. My problem is solved. Thank you @anon35356645, @Danielhiversen
